Question about Toys
My little gyro-copter doesn't charge but it says it has full power.
    Genius:
  • 1,669 Answers
You may have to be a little mechanical and open up the helicoptor to check its battery with a volt meter (if you have one). If not, just disconnect the battery for a few minutes, put it back together and retest. It may be just a simple connection problen from the banging around these toys get!
Posted on Dec 30, 2012
4 Suggested Answers
andrec1024
  • 7 Answers
SOURCE: just got the syma s032
So your only getting 20 seconds of flight time when your charging for a full cycle?
I purchased the Syma Chanook and it had the same problem , If you keep running into this problem using the remote control charger than I suggest to aquire a new charger . One that is a plug in the wall . I really dont like to rely on the usb chargers they just dont work as well. If not you still have a 30 day moneyback warranty and I would make them replace the battery or better yet the whole unit if the second charger doesn't work!
Posted on Dec 24, 2010
bigguy810
  • 448 Answers
SOURCE: FXD RC Helicopter - helicopter
check your controller some of them have a a.b.c switch for different channels look it over good
i have 5 rc helicopters i just bought the 3ft sky king and it has a a.b. switch on the helicopter
hope this helps you
bob
Posted on May 23, 2011
bayyagg
  • 1672 Answers
SOURCE: gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
Posted on Nov 22, 2011
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
How do you turn on an HAK 311
On the copter right above the charging hole, there is a little switch. Left is off, right is on.
My copter has the problem that the remote doesn't work, turning it on does nothing, and connecting it to the copter only makes the light on the remote flash red.
HAK 31 is a piece of junk.
Feb 09, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
Idk if my last question posted but my son got a cheap looking Stinger Bladez with Gyro 3.5 channel r/c helicopter from a friend for Christmas. The remote has been plugged into the helicopter for four...
There are times when you need to check battery contacts on the copter itself, for at times there are plastic protectors between the batteries and the contact points that needs to be removed, these are used to prevent battery power drain while in storage or there might be an on-of power switch on the copter that you might have missed. if all else fails then this definitely is a dud but at least try to make it run ...
Dec 28, 2013 | Shuttle 9094 Emax Remote Control...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Gyropter not lifting off after full charge
Hope that helps!
Nov 20, 2011 | JCPenney Gyropter RC Helicopter
My helicopter (SO32 Gyro) having previously worked perfectly now will only hover. I have tried recharging it but it makes no difference. I wonder if I have overcharged the battery and if it is possible to...
Batteries are available online (amazon and many others) and change easily with only small screwdriver. Overcharging is not the issue. Nearly impossible with PCB (overcharge prevention circuit) hard wired into battery AND in charger. Problem is likely UNDERcharging, overDIScharging, or improper battery care. Battery MUST be allowed to cool 10 minutes after flying. Charge until light on charger doesn't get any brighter when helicopter is unplugged... light comes on (dim at first) well before full charge. 10 minute cool-down after charge also a MUST. And, most important, when flying, as soon as you are unable to maintain altitude, land helicopter and power it off. Li/Po batteries should never be fully drained. Even one full discharge can cripple or ruin entirely your helicopter's battery.
hope this helps.. let me know,
r
Feb 27, 2011 | SYMA Toys industrial Syma S032 Ready to...
I have a nano copter blaster 3D. I have put new batteries in the remote control. When i switch the remot on I get a red light and nothing else happens. It was bought for some friends who returned it...
You have to charge the copter first. Open the cover on the remote control and plug the little cord into the bottom of the copter. Make sure the copter is turned off. Switch on the remote and you will get a green light which means it's charging. When it goes red (about 10 min) it's charged. Then uplug it, turn on the copter and fly!
Oct 10, 2010 | Toys
Toys Logo
49 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
