Question about Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range
Broken door hinge on Stoves 900dfa oven
We have a broken door hinge on our Stoves DFa oven. i have the hinge kit but it has no assembley instructions. we are trying to source the assembley instructions for this model of oven, can someone please help!
    New Friend:
  • 4 Answers
Firstly careful as the hinges have strong springs and it is easy to trap fingers. Also do not lift oven by front door handle as you will break the glass - they cost 170 pounds.
Remove the side panel on the appropriate side held on by 2 screws at the front and 2 at the back. This gives access to change the hinge. Open door and put nail through hole to hold hinge open. Slide inner glass up and remove. The outer door has to pulled off the hinge after removal of the plastic insert which hold its in place and also supports the inner glass. This plastic peg is tricky to get out. If it breaks you have to drill it out! Other than the peg issue it is not a difficult job.
Posted on Mar 31, 2013
    New Friend:
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Posted on Jan 29, 2013
5 Suggested Answers
SOURCE: I have a stoves 1200 dfa and one side of the door
I've got exactly the same problem, in my case I've had to order a new hinge assembly from Stoves, because part of the hinge uses a plastic insert that slides into the door frame and it is broken. I spoke to the technical parts team and they were very helpful.
Posted on Dec 11, 2009
  • 1314 Answers
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Posted on Mar 15, 2008
aardvarkrepr
  • 62 Answers
SOURCE: Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Posted on Nov 18, 2009
Testimonial: "Very speedy answer! thank you."
SOURCE: How do I remove the
My range is a different brand, but the door comes off real easy. Open it to the first detent, and then pull straight up on it to slide it off the hinges. Be careful though, the hinges are spring loaded and if you bump them they will easily come off the detent and slamm to the closed position. This will not only scare the sh..it out of you, but will also pinch your fingers real good if you're not careful.
Good luck,
Gary B.
Posted on Feb 08, 2011
The glass has broken on the outer door of the small oven of my Stoves 1200DFa range cooker, the part is no longer made, where can I get a replacment door/glass from?
Dear Heather.
We have exactly the same problem with our Stoves 1200 DFa since more than a year.
Did you came across a solution in the mean time?I would be gratefull if you would let me know.
Thank you ,Wouter Dikker
Mar 16, 2011 | Stoves 1200DFa Dual Fuel (Electric and...
How do I remove the door on a Stoves 900DFa oven?
Good luck,
Gary B.
Feb 07, 2011 | Stoves 900DFa Dual Fuel (Electric and Gas)...
I have a valor classic 2 si cooker and the door hinge has broken and also the plastic strip on top of the door where can I purchase a new hinge/plastic strip or door?
I have same problem and psoke to valor (now Stoves ) and this item is now obsolete, unfortunately I have had to buy a new cooker.
Mar 19, 2010 | Miele H378B2 KAT Electric Double Oven
STOVES 900DFa not working
Probably a silly Q but does the clock come on?
My \\\\\\\\stoves needs the clock setting before the oven and ignition will work
Feb 14, 2010 | Stoves 900DFa Dual Fuel (Electric and Gas)...
I have a stoves 1200 dfa and one side of the door has come away from the hinge when I opened it. How can I get it back in place?
Dec 09, 2009 | Stoves 1200DFa Dual Fuel (Electric and...
The right hand side of the main oven has broken
You have not given much information to go on, but I am assuming that you mean the door hinge has broken.
If it is a drop down door, then you will have to replace the hinges as a pair.
If it is not the door that is the prob, then I need more information.
Thanks
Please rate my comments.
Nov 22, 2009 | Stoves 720EF Electric Double Oven
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Hi.
Regards
aardvark repairs
Nov 18, 2009 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Stoves 900DFa dual fuel cooker
Mar 15, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
301 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
