My Canon MG4150 printer not printing properly
I've printed loads of times, losing my ink, I've cleaned the rollers and still it crooks. Please, help!
  • 111 Answers
SOURCE: printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Posted on Oct 14, 2008
SOURCE: how to fix my canon pixma ip1000 printer will not print black ink
replace the printer head....
Posted on Jun 25, 2009
  • 117 Answers
SOURCE: MP530 all in one printer - bought Staples magenta
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Posted on Jul 01, 2010
  • 6 Answers
SOURCE: canon ip1000 not printing even after replacing a new ink catridge
This might seem a dumb answer, but have you removed the PULL tab over the breathing hole. I had a similar problem until I realised my error.
Posted on Jan 25, 2011
  • 10406 Answers
SOURCE: My Dell V505 printer won't
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
Posted on May 09, 2011
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
Ink spots on back of printed page from Canon i860. What to do?
Type in your search engine How to get rid of ink spots on back of printed page from Canon i860 printer.
It will take you to How to download a manual that will help you fix this issue. PDF.
Jun 18, 2017 | Canon i860 InkJet Photo Printer
Orange light flashing five times
With the printer on...
Open the lid
Remove the ink cartridges
Lift the print head lock lever on the left
Remove the print head
Gently clean out any ink
Gently clean the copper contacts on the back
Gently clean the print head nozzle(s) on the bottom
Make sure it's dry
Re-install the print head
Put the lock lever back in the down position
Reinstall your ink
Close the lid
Try printing again
The printer may detect that you removed/inserted ink so it may go through a print head cleaning of it's own that you need to wait to finish
If needed, power cycle the printer and then try printing again
You may need to replace the print head
Nov 11, 2017 | Canon PIXMA iP3500 Printer
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon pixma mp780 printing problem
If deep cleansing via software doesn't work then you've got to manually clean your print head unit. Sometimes you'll have to bite the bullet and get a replacement print-head unit ($$). If you're at the stage that you're considering replacement, then you've got nothing to lose by cleaning the print-head unit yourself. It's simple. Remove all ink cartridges first then remove the print head itself. Place the print head unit in a saucepan of warm (NOT boiling hot) water and leave to soak for an hour. (Protect your clothes - it gets messy) After an hour, flush the printhead unit under a running tap. Don't run the water too fast or you may damage the unit) You should flush until the water runs clear. Do not attempt to clear the nozzles with anything other than water - they are very fine needle jets and you will damage them!! If needs be, return to saucepan and leave to soak in warm water again and repeat process. When you are satisfied that the printhead is clean, you need to dry the unit thoroughly. Shake as much water from it as you can then pat it gently dry. Next place it on some absorbant kitchen paper and put the unit in a warm place to thoroughly dry (Overnight in a warm airing cupboard would be good). Once dry, refit the unit put in (Preferably new - but I've used existing one's without problem) cartridges and run a cleaning cycle. Your printer should now work as if new!!! - In Most cases!! - sometimes though, you'll either have to replace the print head unit - which sometimes can be more expensive that simply replacing the printer. What have you got to lose though eh? CLIVUSS
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
421 people viewed this question
k24674
jasbo
jasbo
