Question about Dryers
I have a creda simplicity T620CW condenser dryer. It works for about 5-10minutes then the start button pops out and it stops and you can't push the button in again, can you help please
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
  • 10865 Answers
SOURCE: whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on May 21, 2009
hunter19_46m
  • 7482 Answers
SOURCE: can you supply an instruction manual for a creda
Try this website, maybe you will find out what you need.
I hope this helps
Clothes Dryer how-to instructions. Clothes Dryer help.
laundry.manualsonline.com/manuals/device/clothes_dryer.html
Posted on Oct 03, 2009
SOURCE: creda T620CW condenser dryer
Recently bought condensor dryer which was working fine till the very cold weather came. Is situated in the garage so temp has been going well below freezing some nights. Now keeps switching off after a few minutes and empty water light flashes although resovoir has no water in it. Is this due ti pipes freezing?
Posted on Jan 03, 2011
I want Creda simplicity T620CW manual
Try Googling (creda)(T620CW)(manual) without parens.
Jul 03, 2017 | Creda Washing Machines
Creda simplicity dryer
new interlock then .....cheers
Jan 30, 2014 | Dryers
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Dryers
WE HAVE REPLACED HEATING ELEMENT. AND THERMOSTATS. ON A CREDA T620CW TUMBLE DRYER. AND STILL NOT HEATING UP.ANY IDEAS PLEASE.
Reset overtemp thermostat should be small round disk attached to drum with a little red button.. Press firmly should reset ..
Feb 28, 2011 | Dryers
I HAVE A CREDA SIMPLICITY T620CW WHICH CUTS OUT AFTER A SHORT WHILE AND WILL NOT RESTART FOR A WHILE. IS THERE A THERMAL CUT OUT ON THIS MODEL OR IS IT THE START SWITCH THATS AT FAULT? WHILE IT IS ON IT...
Yes, this model has a thermal cut out and you are correct in thinking that this is the reason why the dryer cuts out and will not re-start for a while.
However, although it's possible that the thermal cut out is faulty, the more likely and common cause is a failed thermostat. If the thermostat fails in the closed (on) position, it means that there is constant power to the heating element. This will cause the dryer to overheat and the thermal cut out will trip to prevent damage to the dryer. A correctly functioning thermostat opens and closes to switch power to the heating element on and off to keep the dryer at a roughly constant temperature.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Dryers
Can you supply an instruction manual for a creda simplicity condenser dryer TCR2
I hope this helps
Oct 03, 2009 | Dryers
How do I replace the belt on my Creda T620CW tumble drier
most credas you need a stretch tool to stretch the belt from drum to motor if there is no jockey pulleys good luck.
Sep 14, 2009 | Dryers
Creda T620CW condenser dryer
Jul 26, 2008 | Dryers
Dryers Logo
101 people viewed this question
Top Dryers Experts
