Question about Compaq Computers & Internet
My pc is showing a white screen when iys on
When its on ist only turning the screen white
  • Compaq Master
  • 27,725 Answers
Is it an LCD monitor ?
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Posted on Dec 30, 2012
Nokia fault
WAS THAT MOBILE FELL NO THE WATER
Jun 25, 2013 | Nokia 6600 Cell Phones
I have an Acer Aspire One D255-2509 laptop and wheneve I turn it on the screen goes blank and there is just a white dash mark in the upper left hand corner. The laptop didnt come with a dics or a dic slot,...
Hi
you could try this
press power on key as well as the FN+F8 key
hopefully this will take you into the repair option
which should give you several options to try to repair the laptop
i always choose the last known good configuration ist that works on a lot of problems
next i would try repair my computer if the ist option did not work
If these options does not fix your problem
you could try this next but you will loose any files or photo,s that you may have put on the laptop
so it always pays to do a back up of your pics etc on a regular basis if you keep adding them
power up and press Alt+F10
this may take you into the acer recovery management
then follow on screen instructions
many thanks
please let us know if this has helped you
so that we may be able to help others
Jul 05, 2011 | Acer Aspire One PC Notebook
White screen
A white screen is caused by moisture corrosion to the screen cable. This is not an easy fix. I suggest an on line auction for iy, and purchase another
Mar 11, 2010 | SanDisk Sansa Fuze MP3 Player
I have a 61" hitachi i was having problems with the convergence 5 was showing on the screen,so i replaced those parts now ist showing #3
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Hitachi 61SWX10B 61" Rear Projection...
The words blare green around them.
revise la convergencia de su tv iy los anillos del cañon
Aug 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Pink pictures
Have you tried changing the White Balance. You can access this by switching on the camera, pressing the Fn button and then the left arrow.
Jan 11, 2009 | Pentax *ist D Digital Camera
Black screen and numbers 2 and 4 lit
The 2 and 4 LED error code indicatesVideo subsystem configuration or failure”. You either have a bad video circuit or your video drivers have a problem. Try booting into “safe mode” by tapping the F8 key when powering on the computer. If the computer comes up in safe mode then your video drivers may have to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 15, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
USB transfer problem--*IST D
I would dig around in http://www.usbman.com to see if any patches for Win ME. Used that OS for about 6 months before dumping it. Not my favorite to say the least. Then again that was a long time ago. Would help to know who's USB chip is in your box. Actually cannot recommend any Win products but XP. Have used Win 3.1,95,98,98se,me,xp home.
Sep 08, 2005 | Pentax *ist D Digital Camera
Computers & Internet Logo
167 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
