Question about Miele Dishwashers
Miele g1140sci not filling with water and amber lights all flashing
  • tom rodger Jan 01, 2013
    More details..... The machine had a piece of plastic in the pump impeller, which stopped it working properly. I have removed this and the pump now works. I also (perhaps unwisely), cleaned out the large plastic side panel, which had a lot of dirt in the bottom of it. Now the machine will start normally, but after about 10secs, all three amber lights flash together and the machine stops. The water cutoff valve is not opening, although it does work correctly when tested off the machine. I suspect that I need some reset method?. I've cleaned out all the pipes etc.Hope somebody can help? Thanks,tom
5 Suggested Answers
SOURCE: Water inlet flashing ,not filling,
Hi Paul,
We currently have a similar problem with our W939. I took the front panel off and found that the Miele service folks had incorrectly routed the ribbon cable linking the fill level sensor with the control panel and severed one of the wires. The machine was reporting a series of errors, one of which was an outlet blockage and the discharge pump was not working.
The relevance to you is that your problem may be a loose or broken wire or corroded terminal.
SA.
Posted on May 04, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
  • 4 Answers
SOURCE: Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Posted on Aug 06, 2009
ercupa190
  • 12223 Answers
SOURCE: Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Posted on Jun 25, 2012
Miele dishwasher G1040 stop starting then all three lights start flashing
Sounds like bad control board. Try calling the guys from the service, I don't think you'll be able to fix this by yourself. Source: PDF Keep
Dec 27, 2015 | Miele Dishwashers
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Jul 25, 2010 | Miele Novotronic Premier 500 Front Load...
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Apr 25, 2009 | Miele Novotronic W1918A Front Load Washer
Flashing start light
Hi, I have the same problem. Did you find a solution?
Oct 29, 2008 | Miele W149 Top Load Washer
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Dishwashers Logo
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
