Question about Apple iPod touch
Ipod touch cannot connect
I bought an ipod touch off a friend and i have the connector and everything, but when I connect the touch to the usb, nothing comes up like nothing's even connected
  • Kiliman Jan 19, 2009
    my ipod wont show up on itunes, i even erased all the conntent on it and it still wont work
  • streetstyle2 Jan 19, 2009
    no, my friend got it to work right away and i know my usb ports are properly workin but its like the computer isn't finding a device
    Problem Solver:
  • 12 Answers
Try a different usb lead or port might be it's faulty. Did your friend have the same issues ever?
Posted on Jan 19, 2009
I have a gen 1 ipod touch which is disabled i have forgotten password and have a new computer with new verison of Itunes I have tried everything to enable ipod with no luck. Please help
Open itunes, connect your Ipod to the computer with the USB cord, a message will come up saying "iTunes could not connect to the ipod because it is disabled/locked with a passcode". press cancel. Unplug your ipod from the USB cord.
Now shut down the ipod, hold in the home button at the bottom and connect the USB cable back up, keep holding the home button down and you will see a picture of a USB cable and iTunes on your ipod screen. iTunes will say it has detected an ipod in recovery mode and would you like to restore it to factory settings? Click restore and sit back for a few minutes until it restores everything to factory settings. Your ipod will reboot and iTunes will detect it. You can then go into the ipod and install a new pass code if you wish to.
Hope this helps,
Rob
Sep 07, 2011 | Apple iPod touch
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
I bought an ipod touch from the family of a friend that just died. the battery was dead on it when i bought it and when i charged it all it says is connect to i tunes so i connected it to i tunes and it...
You need to put your ipod into DFU mode
Step 1. Turn off your iPod.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
After you need to restore your ipod
Feb 10, 2011 | Apple iPod touch
How to conect ipod to the pc
The iPod comes with a cable with a wide-connector at the end that connects to the iPod, and a standard USB-connector at the other end, that connects into any USB port on your computer.
Download: http://www.Apple.com/iTunes the free iTunes software, install it, and use it to copy music from your computer to the iPod, and to purchase music from the iTunes Online Store.
Feb 01, 2011 | Apple iPod touch
Starting up with anew ipod touch
To use iPod touch, you need:
  1. A Mac or a PC with a USB 2.0 port and one of the following operating systems:
  • Mac OS X version 10.4.10 or later
  • Windows XP Home or Professional with Service Pack 2 or later, Windows Vista Home Premium, Business, Enterprise, or Ultimate edition.
  • iTunes 7.6 or later, available at www.apple.com/itunes
  • iTunes Store account (to purchase music over Wi-Fi)
  • An Internet connection
Before you can use any of the iPod touch features, you must use iTunes to set up iPod touch. You can also register iPod touch and create an iTunes Store account.
  1. Download and install the latest version of iTunes from www.apple.com/itunes.
  2. Connect iPod touch to a USB 2.0 port on your Mac or PC using the included cable. The USB port on most keyboards doesn’t provide enough power. Unless your keyboard has a high-powered USB 2.0 port, you must connect iPod touch to a USB 2.0 port on
    your computer
  3. Follow the onscreen instructions in iTunes to set up iPod touch and sync your music, video, photos, and other content. Your computer must be connected to the Internet. By default, iTunes automatically syncs all songs and videos in your iTunes library to
    iPod touch. If you have more content in your library than will fit on iPod touch, iTunes alerts you that it can’t sync your content. You’ll need to use iTunes to select some of your songs, videos, and other content to sync.
When you get back to France, you'll need sync it with your PC. Download the latest version of iTunes then sync your iPod with your computer.
Oct 19, 2009 | Apple iPod touch
THE SCREEN SHOWS ITUNES AND USB CORD
You need to connect it to a PC/Mac to register that iPod with Apple before you can even use it.
Jun 21, 2009 | Apple iPod touch
No power from my IPod touch
http://www.apple.com/support/ipodtouch/troubleshooting/ipodtouch/
go here and click on begin, when you have gone through the troubleshooting page there is another link there for support and more troubleshooting tips and topics.
I hope this helps
Jan 19, 2009 | Apple iPod touch
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
