Question about Olevia LT32HVM 32 in. LCD Television
Remote problems my mother used the tv remote instead of the comcast cable remote to turn the channels and then tried to fix it and now we have no signal or picture
  • 944 Answers
What exactly do you mean by "tried to fix it"? I think that would help us find a solution - nothing you do with a remote for either unit should stop you getting a signal. I suspect all that has happened is that your TV is not on the channel that recieves the cable output, first thing to try is turning both units off by unplugging them from the power supply and leaving them for a couple of minutes, then turn the TV on first, then the cable box - hopefully it will auto select the right channel. If not then you need to pull up the on screen menu to select the input source (should work from the menu button on the TV remote even if you have no input from the cable box) - check the troubleshooting on this link for a more detailed description; http://www.olevia.com/support/troubleshooting_steps.aspx Hopefully this solves the problem, if not then here is the link for the user manual, which has much more detailed troubleshooting; http://olevia.fileburst.com/manuals/323_English_User_Manual.pdf If you need any help with the steps in that then please ask again. If you get no luck still then I would be tempted to suspect either a fault in the cable box itself, or the cable connecting it to the TV or the network. Doesn't sound like this is the problem from what you have described so far - give us more detail please and we can investigate more. Hope this helps :)
Posted on Jun 23, 2007
SOURCE:
I have comcast remote and granddaughter turned tv on side panel. Now screen is fuzzy and I can't find remote that came with tv. I get picture back?
Hello Mary and thank you for choosing FixYa today for your online technical support needs.
When you say the TV is FUZZY, do you mean that there is no picture there at all?
It is possible that your grandaughter may have changed the VIDEO INPUT MODE SELECTOR on the TV by accident when she tried to turn it on with the controls on the TV itself.
Most TVs have a button right on the front of the set itself labelled INPUT which allows you to switch between the various input modes. That button should be located right beside the POWER, CHANNEL, and VOLUME buttons on the TV's front panel.
You may simply need to press the INPUT button and select the proper INPUT SOURCE for your Comcast cable box.
The proper INPUT MODE for your particular setup will depend on how your Comcast cable box is connected to your TV. If your cable box is plugged into your TV with an HDMI cable, then make sure your TV INPUT MODE is set to HDMI.
I hope this helps out, and please feel free to comment back to this page with any additional questions or concerns and I will respond back.
If you do need additional help, please be sure to include the exact model number of your TV and of your Comcast cable box as well as how the two are connected.
Good luck and take care.
Joe.
Feb 14, 2012 | Initial DTV-201 20 in. LCD Television
Trying to connect with Comcast using comcast remote. have idetified correct code and and can turn TV on & off with remoet but can not get channels to change .... just get static no picture ??? Can...
The Comcast remote only changes channels on the cable box. not the tv itself. If you have a cable box then the tv will need to be turned to channel 3 or 4.
Apr 11, 2011 | Quasar VV-1302 13 in. TV/VCR Combo
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
HAVE LG DU-27FB32C LG TV. DO NOT HAVE A LG
There should be buttons on the cabinet to control the TV. Are the buttons on the cabinet not working?
May 20, 2010 | LG Televison & Video
Figuring out the TV channels for Comcast using the Sharp remote
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
Jan 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Olevia LT32HVM 32 in. LCD Television Logo
59 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
