Question about Levelone ServCon WPS-9122 (WPS9122) Print Server
Level One Print Server not serving
I have an Epson CX6600 all-in-one-printer that I want to share with several computers wirelessly. I have installed the Level One WPS-9122 wireless printer router on my Windows XP desktop and I have installed it on my Windows Vista Home Premium desktop. The install does not find a print server in either O/S. I connected the hard-wire lan cable to the computer and the router and the usb cable from the printer to the router.
  • 7 more comments
  • mrgiles746 Jan 18, 2009
    Printer Sharing is turned on on my Vista desktop
    Not running Windows NT
    How do I find and Open the printer's embedded Web server (EWS). I am using Windows Vista Home Premium with a Epson CX6600 All-In-One printer connected by USB to either the desktop computer or the Level One Printer Router.
    The Epson CX6600 is not a wioreless printer. It can only be connected by USB. I have the USB from the printer connected to the Level One print router and a lan cable connected to the Level One router and the desktop.
    No working solution at this time. it's 2AM and I'm head to bed.
    Printer works fine when directly connected to the computer via USB. The problem is getting the printer to work with the Level One WPD-9122 Printer Router.
    I do not have an HP printer or a Cannon Printer. I have an Epson CX6600 All-In-One Printer. I am trying to use the Level One WPS-9122 Printer Router to operate the printer wirelessly and access it from multiple pcs.
    This so0lution will not work with my Epson CX6600. The Epson CX6600 is a USB ONLY connection.
  • mrgiles746 Jan 19, 2009
    I have looked over each of the ideas provided to me for resolving my problem and do not yet have a resolution for my problem. I appreciate each of these suggestions and hope that someone may still have an idea of what I might do to fix this problem. Please continue to share your expertise.
    Guru:
  • 859 Answers
This is the sort of thing you are better off buying a Live Chat from FixYa for and the setup requires a lot of feedback to the tech about what you are seeing and then being led through the setup. Using this for of support is going to get you good and dumb answers and you may not know which is which.
If you wan to continue with this see below, otherwise abandon this Premium Question ask for your money back, that part is easy and then go for a Live Chat session. Only Network Gurus will get the notification you need Live Chat help.
So, maybe to start over is good?
Disconnect the ethernet cable and the USB cable, uninstall the printer software.
Install the printer software again and when IT TELLS YOU to, attach the USB cable, otherwise the installation will fail.
Now, attach the USB cable to the print server and the ethernet cable to the PC. At the back of the router are two different plug IDs. One is an uplink and the others numbered 0-4 or 1-4 attach the PC to one of the numbered ports, choose 2 to be safe. The uplink port will be used for a DSL Modem this is sometimes shared with port 1.
Still, in my opinion, you have a poor hardware choice. All you need is a network adapter for the printer. I wouldn't use a router on a printer server, not for your needs.
There is a RESET button recessed on the back of the router. Use a pen and hold the button is for a full 20 seconds. Use a watch to do this. This will resett everything to factory settings. Then you can start all over again.
If you can't get it or figure it out, see if you can get your money back as what you have is not a smart appliance. Choose another printer server or network adapter would be better.
Posted on Jan 18, 2009
    Sergeant:
    Novelist:
  • 326 Answers
Http://www.ehow.com/how_4424963_printer-wirelessly-between-pc-mac.html
click the above link and follow the 12 easy steps in the link and get your pc and printer connected wirelessly through the Level One WPD-9122 Printer Router. thanks.
    Genius:
  • 1,665 Answers
  • 6,487 Answers
First thing to check here are the connection of the printer to the printer server and then print server to the router, then check the lights on the print server so we can make sure we have a good connection. After that do a test print from the print server by pressing the reset button of the print server for 5 minutes that will also determine if the printer is compatible with the print server that you have,,,,i
    Sergeant:
    Scholar:
  • 199 Answers
Instead of connecting printer to the router .u directly connect the printer and pc with a usb wire without any mediator between printer and pc.it should work properly.
    Genius:
  • 1,011 Answers
Sir,
click this link for more info
    Scholar:
  • 67 Answers
I have developed step by step manual for setting up wireless printers. This manual explain both ways installation through the printer disk and through the printer console.The example I took is a HP printer but installing other printers would contain similar steps:
You can download this manual from this link:
http://rcpt.yousendit.com/643328148/5db1326812c6ea0aa10360f7ae4514db
Thanks
Fixya Support...
  • 470 Answers
Not sure if HP asked you to do this. It is from thier website. Looks like you may have to hardwire the printer to a computer to fix the ip address.
Problems setting up wireless communication
If you cannot communicate with the printer after completing the software installation and removing the network cable, then one or more of the following network settings in the printer might be wrong:
o
Network name (SSID)
o
Communication mode (infrastructure or ad hoc)
o
Channel (ad hoc networks only)
o
Security settings (such as Authentication Type, and Encryption)
Follow these steps to correct the printer's network settings:
1.
Connect the printer to your network with a network cable or to the computer using the cross cable included with the printer.
2.
3.
Click the Networking tab, and then click Wireless (802.11) in the left pane.
4.
Use the Wireless Setup wizard on the Wireless Setup tab to change the printer's settings to match the settings of the network.
5.
Close the printer's EWS, then disconnect the network cable from the printer.
Good Luck
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 18, 2009
    there's a problem on the server on it,, make sure the server is correct,,
    Wireless print servers offer the following advantages:
    • Allows printers to be conveniently located anywhere within wireless network range, not tied to the location of computers
    • Does not require a computer be always turned on in order to print
    • Does not require a computer to manage all print jobs, that can bog down its performance
    • Allows administrators to change computer names and other settings without having to re-configure the network printing settings.
    Antonio Buenafe Jr. Jan 19, 2009
    if the solution is not wat you want , why did you rate it as fixya??
    President:
  • 2,110 Answers
  • 827 Answers
Hi Mr Giles,
If you click on your Network icon in the bottom right hand corner of your Vista Desktop, and click Network and Sharing Center, is Printer sharing enabled?
Chris (ziraffa)
    Sergeant:
  • 221 Answers
Use the Deskjet printer embedded Web server (EWS) to do the following:
  • Adjusting network configuration
  • Configuring network security
  • Restricting access to Configuration pages
  • Checking printer status and estimated ink levels
  • Viewing network statistics
  • Linking to HP's Web site for support
  • Ordering supplies Do the following two items before opening the EWS:
    • Make sure that the printer and the computer are powered on and connected to the network. To access canon support through the EWS, the computer must be connected to the Internet.
    • Print a Network Configuration page. Note the IP address and the URL of the printer. To print a Network Configuration page, press the Network button while the printer is turned on and idle.
    If the printer has just been connected to a network, it may take a few minutes for the printer to determine its network settings. Wait a few minutes before printing the Network Configuration page in order for the network settings data to be valid. Follow these steps to open the printer's EWS:
    1. Open an Internet browser. Use Internet Explorer 5.0 and higher or Netscape 4.75 and higher.
    2. Enter the URL of the printer in the address box, and then press Enter .to ghet the exact information just click the link below its for hp printer but you can follow on your canon printer. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00202841&lc=en&cc=us&dlc=&product=467982&rule=14
2 Suggested Answers
SOURCE: Level One WPS-9122 Print Server not functioning
Problem not solved.
All help oprovided did not help to solve the problem.
I am returning the print server to the seller.
I would like a refund of the $9.99 I paid for the Premium service.
Posted on Jan 19, 2009
How do i connect my epsonR300inkjet printer wirelessly
Network printing with a non-networked printer
This model printer has only an USB printer connection andnormally connected to a computer or laptop.
To connect this printer wirelessly to all laptops on your wireless networkthere are a couple of methods.
Connect the printer to a desktop computer and setup the printer as a sharedprinter. Next connect the desktop computer to your wireless router with a LANcable and then configure the wireless laptops to connect to the shared printeron the desktop computer. NOTE - This desktop computer and printer must be on atall times for the wireless laptops to print to the printer.
OTHER METHOD
Connect the printer to an USB print server and connect the print server to thewireless router with a LAN cable. The printer drivers needs to be installed onall the wireless laptops and then the printer port needs to be deleted from theUSB port and a new IP address printer port installed. This IP address will bethe IP address of the print server.
Mar 31, 2012 | Epson Stylus Photo R300 InkJet Printer
How can I add a brother 145 printer so all laptops in the house can use it wireless
This model printer has only an USB printer connection and normally connected to a computer or laptop.
To connect this printer wirelessly to all laptops on your wireless network there are a couple of methods.
Connect the printer to a desktop computer and setup the printer as a shared printer. Next connect the desktop computer to your wireless router with a LAN cable and then configure the wireless laptops to connect to the shared printer on the desktop computer. NOTE - This desktop computer and printer must be on at all times for the wireless laptops to print to the printer.
OTHER METHOD
Connect the printer to an USB print server and connect the print server to the wireless router with a LAN cable. The printer drivers needs to be installed on all the wireless laptops and then the printer port needs to be deleted from the USB port and a new IP address printer port installed. This IP address will be the IP address of the print server.
Jun 09, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i make my computer except my epson nx110
What OS are you using? Drivers and software are available here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=128284&prodoid=63084353&infoType=Downloads&platform=All
Did you install the software before connecting the printer? If you didn't, uninstall the OS basic driver, unplug the data cable and install the appropriate one from the above site. Then reconnect when prompted.
Try a new data cable (scanners can be extremely sensitive to cable problems but a really bad cable will not let the printer talk to the computer at all). Make sure the cable is 6' long or shorter. If you use a print server or USB hub, try a direct connection. Check that a known working device works in the USB port. Make sure that the USB ports are active and not powered down for energy savings or security. (In Windows the first is part of the Advanced Settings from the Screen Saver set up control panel; the second is in the Device Manager.)
Is the computer with the problem connected directly to the printer or is another computer serving as a print server? If it is the latter, make sure that the firewall isn't blocking access. Make sure that the printer is a shared device (Devices and Printers (or Printers and Faxes), right click on the printer's icon and choose Properties. Then adjust the Sharing properties on the host computer.
I hope this helps.
Sep 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Problem not solved.
Jan 18, 2009 | Levelone ServCon WPS-9122 (WPS9122) Print...
Epson CX6600 printer does not print
Make sure the tape is removed from the cartridges and that they are the correct ones for your model printer.
Jan 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Does not find a print server
Don't know for sure what the problem is, but I would try hooking the printer to the computer with a USB cable and then see if the print server "sees" it. Usually then you can unhook it, put the lan cable back on, and the print server will find it. Or, sometimes I have clicked on the printer properties, then searched till I found the IP address. Then manually put the IP address in where it asks for it under "add network printer". By the way, my print server hooked up to the router, and to make it work the first time I had to plug my printer into it. Then I was able to unplug it, and use it normally.
Jan 02, 2018 | Levelone ServCon WPS-9122 (WPS9122) Print...
Dx9400f wifi dosent work computer wont see printer after setup ive tryed contacting epson but they are no help, it is ok during setup untill you remove the lan cable then nothing. do you think it could be...
Hmm, not easy to say, are u using a laptop to connect your printer or are u using a ordinary pc connecting thrue a wireless router?
Give me some more info and i will try to help you.
Nic
Nov 19, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Converting to a wireless printer
hi,
if you hav a usb port on the printer you can make it wireless by using "wireless upgrade kit"....
u have t connect this device to the usb port on the printer and you can make it wireless. and if you dont have a usb port on the printer, you cannot make it wireless
thanks and regards
agnel
Mar 05, 2008 | HP PSC 1610v All-in-One Printer
Epson CX5800F printer Netgear PS121 Print Server difficulties
Here is a workaround:
http://newsgroups.derkeiler.com/Archive/Comp/comp.periphs.printers/2007-08/msg00456.html
Another thing to try if it STILL doesn't work is
Printer&Faxes>>Properties>>Advanced>>"Print Directly to Printer"
Just remember to restart after you try both of these. The Status Monitor in it's current for (at least for me) simply sucks.
Dec 04, 2007 | Epson Stylus CX5800F All-In-One InkJet...
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Levelone ServCon WPS-9122 (WPS9122) Print Server Logo
458 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
