Question about Vizio 42 in. LCD TV
Vertical lines on vizio vo420e - Vizio 42 in. LCD TV
  • Vizio Master
  • 8,617 Answers
Thats usually caused by the Tcon board. You can get the replacement inverter board from www.tvcircuitboards.com
Posted on Dec 30, 2012
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I am considering the purchase
Yes it does suport the hdcp. you can see the specs here on link below.
http://www.dealtime.com/xPF-Vizio-VO420E
Posted on Nov 22, 2009
budmrtn
  • 11361 Answers
SOURCE: Vizio VO420E " TURN ON, tv is showing no picture
It can be the main board, power supply, backlight inverter, etc.
You need to do some troubleshooting to narrow down the probelm, so please read my guide first.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Nov 25, 2010
  • 1606 Answers
SOURCE: can i replace a vizio screen model #VO420E with a vizio screen model #VO42L FHDTV10A?
Hopefully you did not try to take the circuit board from the broken LCD and graft it onto the good one - the possibilities for problems are enormous.
Double-check all of the connectors, then compare the model numbers of the main board and power supply between the two sets. The cable between the LCD and the main board is often rather fussy and delicate - DO NOT pull on the wires! You may have to swap cables also. If the main board is different, try the one that went with the good panel (from the VO240E), and hope that part is good.
Note: electronics are susceptible to damage from static electricity. Handle the circuit boards only by the edges, and try to maintain contact with the metal shielding parts as much as possible (an anti-static wrist strap is a good means) while working on the set to discharge any static buildup on yourself.Once you are done, there is an e-Bay market for the remaining parts. If you have identified the bad board from the VO420E (by elimination), you can get more for the others, and you may still be able to sell the bad one to a reconditioning company, who will repair it and resell it.
The worst case situation is that the LCD panel driver board is bad, but as I understand your situation, the VO240E wouldn't turn on anymore. That is usually a power supply problem.
Posted on Dec 11, 2011
I can't figure out how to hook up netfix to my TV. my remote has nothing on it to connect to netfix can you help me
Hello, David -
For one thing I do not believe your model of Vizio TV is a Smart TV.
See the specifications for your model (first manufactured in 2009) here:
https://www.cnet.com/products/vizio-vo420e/specs/
Best wishes.
Mar 23, 2018 | Televison & Video
How do you fix white vertical lines on Vizio tv.
Any horizontal or vertical lines on a LCD pane, 90% the chance that is a defective LCD panel.
Aug 01, 2017 | Vizio Televison & Video
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
The vizio remote nor the comcast remote will turn up/down the volume or power the tv on or off
The comcast codes will give u a list to try just start going down them but not all of the codes are compatable
Sep 13, 2012 | Vizio VO420E 42 in. LCD TV
Half my screen has vertical lines
it sounds like one of the upper flex tab bonds on the set may be the issue. Thats usually whats at fault with that type of symptom.
Jun 09, 2012 | Vizio VO420E 42 in. LCD TV
Vizio VO420E 42 in. LCD TV -- Less than 3 months old. Picture slowly darkens and then goes out all the way. Sound stays on. Picture goes out. We turn the TV & cable box off, wait 30 seconds, turn...
the problem its the main board of the tv not the power supply board.the main one controls all your imputs tv av component etc the cheapest place to find it its at www.shopjimmy.com cheaper than the manufacturer and those dudes that you find online that charge an arm and a leg just to come and just repair your old main board mine as well buy a new one at this site for less ok and you are welcome
Apr 13, 2010 | Vizio VO420E 42 in. LCD TV
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
136 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
