Hi I have a philips 42pfl7403h and it wont start. The led in front blinks three times and after short paus blinks three times again. I checked powerboard for something obvious as burned places etc but i looks alright but still it doesnt work. What is the excact problem when led blinks three times?
welcomejee
  • 10594 Answers
SOURCE: red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
Posted on May 13, 2009
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
hemantraj
  • 638 Answers
SOURCE: my KDF-55WF655 power led blinking red six times.
oh ho try a hard reset mostly u will solve.
Posted on Jun 13, 2008
SOURCE: Sony KP-51Ws520
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Posted on Jul 16, 2008
ladywinn
  • 5138 Answers
SOURCE: Samsung HL-S5679W won't start - LED light blinking
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
1-800-628-1118
Posted on May 11, 2010
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
My TV's icon light blinks 3 long pulses and then 1 short pulse.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 22, 2015 | Televison & Video
What may cause screen to turn green and then black out.? power LED is blinking three times then pause and repeat. unplugging tv did not resolve problem. single click can be heard from center of tv wh
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jul 05, 2014 | Toshiba Regza 55SV670U LCD TV
Why doesn't it turn on?
Dec 10, 2013 | Toshiba 42TL515U 42 in. 3D TV
Won't fire up. LED light blinks 3 times, pauses then 3 blinks again.
Three blinks is a common symptom of a convergence short circuit. If you goto www.TvRepairKits.com look for their convergence kits for you model. They have put together kits that include OEM parts and step by step photo instrucitons.
Jun 06, 2010 | Panasonic PT-56HX41 56" Rear Projection...
I need instructions to turn off service light in 1995 850 volvo
Keep pen and paper ready, as you might have to write down error-codes as you want to do this.
Turn ignition OFF
open the lids of the diagnostic sockets situated in front of the enginecompartment (by the fillercap for the windshieldwasherfluid)
Put the socket with a short lead on in the hole marked "1" on module A
Turn ignition ON
press the pushbutton on the top for about 1 second and WAIT.
The LED will blink in a sequence that indicates if there is any problems that need to be solved.
The led will blink 1 to 5 times, have a pause, blink 1-5 times , have a pause and blink 1-5 times.
Write down the sequence as you count the blinking. eg: 1-3-1
When one sequence is finished, you press the pushbutton again, and read the next code.
Repeat this until you read the first code again.
If the first code reads 1-1-1, all is OK and you can proceed.
After this you can reset the servicelamp:
Leave the connector in socket 1 on modula A.
Turn ignition OFF
Turn ignition ON again
Press the pushbutton for 5 seconds. Be patient.
Release the pushbutton and wait about three seconds, then the LED starts to blink rapidly
press the pushbutton for 5 seconds again and release it.
Turn the ignition OFF
Remove the connector from the socket, replace the lids and put the connector back in its rest.
Turn on ignition and start engine, the service lamp should not be on.
Any error-codes? Refeer to a Volvo-dealer.
Jun 30, 2009 | 1995 Volvo 850
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 20, 2009 | Televison & Video
Philips 42PF9630A Not Working - Red Led Blinks 7 Times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
May 11, 2017 | Philips 50PFP5332D 50 in. Plasma...
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
