About 1/4 of my SYNCMASTER S19B300 have horizontal flickering lines and sometimes the lines becomes too solid that it completely obstructs your vision
4 Suggested Answers
SOURCE: Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Posted on Sep 06, 2008
mitch_3020
  • 70 Answers
SOURCE: A black flickering line about 5" from the bottom on my samsung syncmaster 793s 17" CRT Monitor
Hi rkarthea,
Well to narrow down the problem I would suggest first that you try to disconnect the monitor from your APC Back-UPS and just plug it directly to the wall outlet, UPS or surge protectors may cause interference at times with some electronic devices. Then if it's still here, I would recommend that you try to degauss the monitor, all CRT monitors have this option in the OSD. You should also check if there is any magnetic device near the monitor, like a speaker or phone that can cause this. If another PC is available can you try it there also, see if the problem is seen on another PC.
Finally, run the monitor self-test, to do this just leave the monitor plugged into the power outlet and disconnet the video cable, and you'll see it. If the problem is still there then most likely the monitor will have to be checked in a service center or be replaced eventually, since this would already be a hardware problem. Especially since you said the problem is apparent even in the OSD.
Hope this helps!
Peace! :)
Posted on Oct 23, 2008
MrDallasIT
  • 91 Answers
SOURCE: SyncMaster 940B
Sounds like you have a video card problem. If it works on someone elses PC and not yours. Replacing this video card on your PC should fix it..
Posted on May 14, 2009
How to fix white horizontal lines on middle of screen of a PC monitor?
Need to check removing LCD ribbon cable in the monitor. but it is may be a damage of LCD screen ,need to replace the lcd.but in very first check and service the lcd.
Feb 22, 2016 | Samsung Syncmaster S20b300b - Led Monitor...
Horizontal is flickering
flickering as the picture becomes smaller and bigger or are there lines showing up? Please describe it better if you can so I know exactly what you are seeing. Any color changes?
Jun 28, 2008 | iLO LCT32HA36 Television
TO USE SYNCMASTER s19b300 WITH hp MINI COMPUTER
My monitor is SyncMaster S19B300 it doesn't open at all nothing appears on the screen and idk what to do help please
Jan 13, 2013 | Samsung Computers & Internet
SyncMaster 940B
May 14, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
Unstable horizontal on Toshiba 61H71 Projection TV
Here's an oddball, but if you have some thing similar, hopefully helpful. The problem turned out to be the focus anode (coming out of the flyback, going to the focus block) had broken loose enough to start arcing inside the flyback. Gently pulling the wire out of the flyback, clipping, stripping and tinning the end, and gently pushing the tinned lead back in until it locked proved to be the answer.
Mar 06, 2009 | Toshiba Televison & Video
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
