Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
I have a phillips 60'' and has yellowish color around the edges
  • tintntunes Jan 18, 2009
    im waning to find what i need to replace to fix the problem
  • Philips Master
  • 3,459 Answers
Fluid
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Jan 26, 2009
  • Edward
    Edward Feb 16, 2009
    Your TV most likely has one or more possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
  • 744 Answers
Hi the problem the picture tube of ur tv has got repaired. pls rate me
Posted on Jan 18, 2009
Halo around blue, extremely bad when watching
The CRT coolant in the Blue CRT needs replacement. The green will soon follow. Very common problem with phillips. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant and the CD with instructions.
May 10, 2010 | Philips 60PP9363 60" Rear Projection...
White glow around images. been getting worse over the last couple months.
Could it be blue glow/ blue focus. Probably blue CRT. Put color to min. in menu and is yellowish or bluish where it should be black parts of pic?
Apr 13, 2010 | Philips 60PP9352 60" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
KDF-E60A20 LCD rear Pro HDTV The screen is discolored with a yellowish tint, it looks like it's bleeding down to the bottom, any thoughts?
Your light engine is shot. The coloration is from the the polorised film over the LCD panels being over heated due to inproper ventalation. Due to dust on the vents/and smoking in the home. it clogs the internal filters,and reduces air flow for cooling. Basicly buy a new one,too costly to repair. Part # A-1132-204-A
cost...$949.99 + $1100.00 core. It will also start turning blue around the edges ok the tv. Or turn green. Sorry for the bad news. Todd toddthetvmd@yahoo.com
Oct 31, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a philips big screen tv that has double color around edge. iI was informed it was convergence integrated circuit were is that located on the set
It is located internally and can be identfied by looking for the large heatsinks (aluminium) the ICs (two of them) would be labelled STK...
Sep 18, 2009 | Philips Magnavox 60PP9701 60" Rear...
Sony xbr 60 grand wega color problem.
It sounds like to me you have a bad Optical Block. It is a expensive repair and you may want to call Sony at 1800-222-SONY and see if the would assist you in repairs. Due to the age of it, they would probably only cover a partial amount of the repair.
Hope this helps,
Skyassoc
Jul 23, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Phillis 55pw9363 yellowish - greenish picture
cleaning the CRT lenses and mirror will help, however with that model I would suspect that the gree and blue CRT needs the coolanr changed to get a your color and clarity back. thats a common problem with all phillips rear projection TVs
Jun 13, 2008 | Philips 55PW9363 55" Rear Projection...
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
Feb 03, 2008 | Toshiba TLP S30 Multimedia Projector
60" HDTV Projection
If it looks like the picture is yellowish all through it, then you will have to have the coolant replaced in all three CRT's. It is not unusual for algae to grow in the resivors.
Mar 14, 2007 | LG RU-52SZ30 52" Rear Projection...
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
