Question about GE JVM1440 Microwave Oven
GE microwave Turnable turns on opening the door
We have a GE combo microwave. Start from today, the turnable starts to turn when the door is open but stop when the door closed. It still cooks.
Major concern is if the turnable turns when the door is open, is there microwave leaked out? Can I use it since it still cooks.
What could be the cause of this? Is this some thing DIY?
Thanks.
  • 4 more comments
  • bianxi Jan 18, 2009
    Model is JTP85woa2wwp
    Major question is:
    is there microwave leakage when the door is open?
  • bianxi Jan 20, 2009
    I Could not find the mini-manual, do I need to open the side panel to find it? I think I still have the manual, is there some pages will help?
    For the model, I am enclosing an image of the sticker. Hope you can help me to fix this.
    Thanks very much.
  • William Miller
    William Miller May 11, 2010
    There
    should be a "mini-manual" (tech sheet) hidden inside the unit
    behind the
    control panel or hidden on the left side behind the grille, which is
    very helpful when troubleshooting, testing, and locating components.
    If you can find that and send me a good clean copy of at least the "schematic" page, I can probably tell you what's wrong.
    One problem is an easy inexpensive fix you or someone you know can do, the other would be circuit board repair, which we do
    for
    customers nationwide by mail for $39.95 postpaid in about a
    week with a one-year guarantee.
    You
    can either scan (at 300 dpi) and e-mail the page to me or fax it (in
    "super fine" or "detail" mode) toll-free to 866-481-2802.
  • William Miller
    If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
    So until it is repaired,
    please leave it unplugged.
    I doubt it's actually cooking with the door open, but it can happen.
    One way to tell if it's actually heating when the door is open is to put a cup of water in it and let it set for a minute with the door open.
    Stay away from the front of the unit when you do this to avoid possible burns.
    That model number doesn't look right. Is it possible the microwave's model number (on a tag inside the cooking cavity or around the door frame) might actually be JTP85WA2WW?
    To help you further, I would need a little more info, including the correct model number.
    There
    behind the
    for
    You can either scan (at 300 dpi) and e-mail the page to me or fax it (in "super fine" or "detail" mode) toll-free to 866-481-2802.
    Feel free to contact me directly (and please remind me of your
    full model number) for more information & help.
    William E. "Ed" Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
  • William Miller
    It may be a bad door switch or mount or a shorted relay on the control board.
    What is your model number?
  • Anonymous Mar 16, 2014
    Go to open door, table stops, light goes on, door won,t open.need to slide think metal piece under t activate it . Help!
  • GE Master
  • 9,086 Answers
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
terminal.
See these files for help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jan 23, 2009
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
Magic Chef MCO160UQ Carousel turning slowly
The turnable motor is going, the buzzing indicates the magnetron is about to fail. I suggest using the microwave oven until it dies and replace it, not cost effective to repair.
Apr 14, 2012 | Magic Chef MCO160UQ Microwave Oven
Turnable is still on when the door is open, it does not stop
It may be door switch or switch mount trouble.
See our help file on door switches here.
Or it may be a shorting relay on the control circuit board, which can be repaired. More info here.
Oct 08, 2011 | GE JES1290 Convection/Microwave Oven
Ge microwave jes1290sk02 turnable spins when door opens but stop when door is closed
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides.Since the table turns without a program start and If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
Thank you using Fixya
Aug 22, 2011 | General Electric Ge JES1290ML Microwave...
Microwave still running after I open the door .It's a Turnable Micro Oven Moder JE1540GW003
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Feb 16, 2011 | GE Microwave Ovens
The problem is that the TURNABLE DISH not turning when switched on? Any ideas?
A lot of these are belt driven. Open the case and inspect the drive to the turntable.
Nov 02, 2009 | Siemens HF17025GB 900 Watts Microwave Oven
Turnable plate isn't working
in order to be 100 % sure
you would have to check voltage to the motor while its suppposed to operate
take off the bottom 6 screws, you might need whats called a safe t, a torque wrench or star with a hole
most use phillips,
drop the bottom, you should see the turn table motor
disconnect the two leads and connect them to a voltmeter,,,
turn the unit on
you should read voltage to the meter
if not the problem is in your control board and will need to be replace
if you do read voltage and the motor is not turning
you will need to replace the actual motor
either way its a pretty simple repair and can be done without taking the unit dwon
Oct 24, 2009 | GE XL1800 1100 Watts Microwave Oven
Need replacement glass turntable
looking about $65 from jacobyparts.com and and sears parts
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave the plate not turning
remove power. turn it upside down. remove access cover and determine if there is a mechanical obstruction...could even be belt driven with a broken belt.
Oct 19, 2007 | Microwave Ovens
GE JVM1440 Microwave Oven Logo
1,588 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
