Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
Setting up router
We just bought a tew-432 router and had the network secured at the store. The tech told us not to install the disk in the box or we would undo everything he just did. Then how do I get it to work if I don't install something? How do I get my pc to recognize the network he setup for us?
    Novelist:
  • 176 Answers
You would have to configure your wireless network adapter on your PC and with the same security authentication type.
Posted on Jan 18, 2009
Set password
Download the user guide from here
TRENDnet Support TEW 452BRP 108Mbps Wireless Super Broadband Router
1. Go to Wireless on the management menu.
2. Got to Security on the next menu and change the wireless security from disabled to your choice of security setting and then follow the prompts. Page 31
Apr 19, 2014 | Trendnet 108Mbps Wireless Super G...
My router tew652brp do not work. I set factory default.I do not know about the setting. I can enter into router configuration from internet browser, but I don't know how to configure and set it to factory...
Launch the Wireless Configuration Utility by clicking on the icon in your notifications are.
Click on the site survey link to view available wireless networks. Select your network and click Connect.
If you have secured your wireless network you will be prompted to enter in the encryption key. Enter it and click Apply.
You will now be connected to the wireless network and the parameters will be saved under the profile link.
Oct 26, 2010 | Trendware TEW-652BRP Router
How retrive network key for TEW432BRP
The key number should be on the bottom of your router. That, or log into its administration page (username and password is also on the bottom of the router) and look for the wireless security settings.
Jul 29, 2010 | Trendware TEW-432BRP Wireless Router...
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How do i secure my wireless router from unsecured? trendnettew432brp
Hello
You can can use the WEP or WPA Security key.
For which you need to open the GUI (Router Page Setting and under wireless Choose the WEP - Choose the password
which will secure your router and will prompt for wireless key ..
SSID & Network Key
Jan 07, 2010 | Trendware TEW-432BRP Wireless Router...
I cant connect my new laptop to my Tew 432 brp trendnet router
Sounds like you may be having an issue with software already installed on the laptop to control the wireless connection. Many laptops have preinstalled software for their internal wireless devices. You should consult your manual about configuring and saving passwords for a network for that particular device. Typically you will need to enter the WEP key in the software itself.
Aug 23, 2009 | Trendware TEW-432BRP Wireless Router...
Vista ultimate 32 not connecting to wireless
169.254.x.x IP suggests that your NIC is not communicating with the DHCP server of your Router. Try disabling/enabling the NIC card and in the TCP/IP properties, make sure that the IP address is configured as "Bobtain IP address automatically"
Also try installing the latest drivers for your NIC card.
May 13, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Change from 'unsecure' to 'secure' router
You don't need to install anything extra to secure the network. It's a matter of changing router settings. You set up the router through your web browser by going to "http://192.168.0.1" which accesses the device's setup screens.
There are several revisions of this product. Here is the URL for D-Link's selection page for the router:
http://support.dlink.com/products/revision.asp?productid=di-524
Click on the picture that shows the version you have, and then you'll be taken to the page for that version. You can download a manual or look through the FAQ's which will guide you through the process of setting up the security.
Jan 01, 2009 | D-Link AirPlus DI-524 Wireless Router
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
150 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
