Question about Samsung Refrigerators
Samsung RSA1WTMH side by side fridge frosting up
Freezer top section is frosting up
  • 212 Answers
SOURCE: hoover classic fridge/freezer frost free - fridge
check your vents for good air flow
Posted on Jun 21, 2009
projdoc
  • 2237 Answers
SOURCE: Dometic RM763. Freezer=Yes,Fridge=No
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 21, 2009
MNTECH
  • 1543 Answers
SOURCE: Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Posted on Oct 20, 2009
Sea Breeze
  • 4654 Answers
SOURCE: fridge part of my side by side registers above 40,
Look into the back of the freezer to see if frost is building up on the rear panel. If yes that is a sign of the defrost system failed. I will need your model number. When most refrigerators begin the problem it is a sign that defrost is not happening. Ice makers stop working above 5 degrees. Send me your model number and I will help you get this solved or pointed in the right direction, Sea Breeze
Posted on Feb 13, 2010
Testimonial: "really appreciate all the advice given by Sea Breeze...excellent response time also."
  • 70 Answers
SOURCE: Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Posted on Aug 10, 2010
Samsung RL38SCSW Fridge Freezer not Cooling
Sounds like an air leak around a door seal or the ice maker chute door is open causing frost buildup on evaporator and everything inside the freezer. You also may have a defrost drain line blockage
APPLIANCE 911
Jan 07, 2016 | Samsung RL38SCSW (113 cu ft
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
I bought my samsung rsa1wtmh fridge/frezer over two years ago and it has been troublefree for all that time. Over the past two days it has now developed what I can only describe as a motor noise behind the...
YOU MORE THAN LIKLEY HAVE A OVER FROST PROBLEM
ie freezer has made to much ice , you probaly will only need to switch off for 24 hours to let excess ice to defrost ....
click here for
samsung fridgefreezer problems
also have alook at .......
rsa model really only developes this type of problem , which as i said can be easily sorted by allowing appliance to defrost ...">
Oct 22, 2010 | Kitchen Ranges
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
GE Refrigerator Model GSS20IEDPD
check the back panel inside the freezer section near the lower shelf (not the bottom bim) for frost
Oct 14, 2007 | Refrigerators
Refrigerators Logo
152 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
