Question about Cycling
Iv got Shimano Alivio 9speed shifters. My front derailleur cable is damaged so im attempting to replace it. Iv detached the cable from the derailleur, iv opened the front shifter covers, but I'm not able to find any kind of release mechanism for the cable. I'm stuck... Can anyone help? Please explain how I can release the cable from the shifter.
    New Friend:
  • 21 Answers
If there is no internal routing under the covers, check the sides near the triggers. There will be a black plactic phillipes head screw. Shift the derailleur down the high gear or where all the tension is released from the line. Disconnect the cable and feed it backwards towards the shifter. the cable will come out the hole where the cable previously was inserted
Posted on Jan 03, 2013
4 Suggested Answers
  • 37 Answers
SOURCE: Shimano top swing front derailleur fitting - help
Go to Parktool.com it's real easy. good luck
Posted on May 26, 2009
bikeservice
  • 34 Answers
SOURCE: Shimano 105. Front derailleur won't shift down
It sounds like you could have two different problems. Your derailleur has become contaminated or your shifter may need to be lubed. Either way, the likely solution is the same. The best solution to get the derailleur operating again is to spray it with GT-85 or PB blaster and manually move in back and furth until it is working again. The same goes for the 105 shifter, spray GT-85 inside the shifter by compressing the brake lever and spraying towards the head of the shift cable. This will solve a non-functioning shifter many times.
The only other problem that fits is the limit screws could be wrong or the deraileur is in the wrong position. This would not be the case unless someone adjusted your derailleur before the ride you started have that problem. Or if the derailleur has moved. Both of which require the derailleur to be fully readjusted.
Hope this helps. Thank you
Posted on Jul 17, 2009
  • 484 Answers
SOURCE: Shimano Deore LX right hand rear shifter
HERE is Shimano's exploded-view diagram of the shifters, but it really only gives you a ballpark idea of the assembly. You will have to piece the rest together from memory, i suppose. Sorry, i could not find more information for you.
Hope this helps a little,
matt
Posted on Oct 08, 2009
Hi! I bought a 2nd hand bike - actually it is more 3rd or 4th hand. The brand is called "Gazelle" and brakes and gears are from Shimano. Model Type of gears: Shimano Alivio FD-MC14, seems to be...
http://www.parktool.com/blog/repair-help/front-derailleur-adjustments
If you mean you can't get to the LARGE chainring, that would follow as the cable must be pulled the farthest to get to it. There are limit screws for each end of the derailluer's motion. You're probably fighting that adjustment. With the shifter tension on the cable totally relaxed (small chainring position) you should be able to manually grab the front derailleur cable as it runs along the downtube and, while pedaling the suspended bike, pull it away from the downtube and reach the highest chainring and, when released, the lowest chainring without dropping the chain. That's what the limits are for. THEN you adjust the cable tension and tweak it all. Web search for procedures like "how to..." just about anything and many resources will appear, some with video.
Sep 06, 2011 | Mountain Shimano Alivio Front Bike...
The shifter will not move into the # 3 range on the front derailluer, problem is in the shift lever
Check the limit screws. It is likely that the limit screw is adjusted to keep the movement limited to the first two chainrings. If that is not the problem, alignment or damage may be the source.
Jan 07, 2011 | Mountain Shimano Alivio Front Bike...
Good evening - I have Shimano Alivio Gears on my Cannondale F6 MTB and the gears are trying to change down a gear on the rear cogs (go to the larger cog) and need adjusting - which screw is the one to...
Neither screw is for mis-shifts. Those are limit screws for the largest and smallest cogs. Tweaking the cable tension will usually bring in the indexing...
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
It sounds like your cable is/was a smidge too tight.
Aug 14, 2010 | Mountain Shimano Alivio Front Bike...
My Shimano Alvio 3-speed front shifter has
rough guess, from past life of bmx.
there should be a cable that runs down to the mechanism, the cable is secured by a small nut, loosen the nut and pull the cable a little more out of the nut with pliers. tighten the nut, and try the linkage.
the shift cable stretches over time and your actually gonna make a small adjustment to compensate for the stretch. by just pulling the cable thru the locking nut to make it shorter.
Jul 31, 2010 | Mountain Shimano Alivio Front Bike...
Alivio 8 speed rear derailleur cable broken
There is a bolt on the derailleur that holds the cable. Loosen it to remove the cable from the derailleur. If there is a cap on the cable, remove it by pinching it with a pair of pliers. i do not know what style shifters you are using, but most all of them have a plastic cap covering the port for the cable. Shift to the highest gear to prep the cable for release and remove the cap. Push the cable back into the shifter and it should come out of the port you opened. Now, slide the new cable in and pull it through its circuit of cable housings and back to the derailleur. Attach the cable and shift to the lowest gear (big cog). Now, pull the cable along the top tube or seat stay (wherever it is more accessible) away from that tube very firmly several times. This pre-stretches the cable and minimizes necessity of adjustment later. The harder you pull, the better. Once you have stretched the cable, shift to the highest gear again and release the cable on the derailleur. Adjust the barrel on the derailleur to the center of its range and turn in the one on your shifter all the way. Now, pull the cable taut and reatach it on the derailleur. You can cut the cable to length and put a cap on it now. Shift into your middle gear and use the barrel adjuster on the derailleur to align the jockey wheel over the appropriate cog of the cassette. You should be all set!
i hope this helps
-matthew
Nov 12, 2009 | Cycling
7 speed alivo shifter no down shift
Hi log onto shimano.com and you will find what you are looking for
Oct 15, 2009 | Mountain Shimano Alivio Front Bike...
Hi, I was riding this weekend and when i got to a steep hill i attempted to shift down from my large ring at the front, but this failed. When i am pressing the inside lever to shift down the is no click...
This is somewhere between solution and clarification request: if you disconnect the cable from the derailleur and shift up and down, does the shifter click as it should? If not, you need to disassemble and clean your shifter.
Jul 15, 2009 | Shimano 105 Triple Braze On Front...
Cycling Logo
335 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
