Question about HP LaserJet 3055 All-In-One Printer
Printer hp 3055
Hp 3055 Printer not working properly error msg "49"
    President:
  • 2,692 Answers
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
How to solve scanner error 5 in HP LASERJET 3055?
The stepper motor controlling the scan arm is defective. Replace motor or entire unit.
Aug 07, 2014 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer "49 error turn off"
The 49 code is related to one of three things on this unit.
1. You accidentally used a refurbished toner instead of one directly from the manufacturer which tends to cost a bit more. The certified one from the dealer is known to clear this error code instantly.
2. Your internal memory cash will need to be reset
3.You have internal hardware failure which can not be repaired by the user and must be sent to the manufacturer.
Mar 22, 2013 | HP LaserJet 3055 All-In-One Printer
Scanner error 3 hp 3055
Found this solution....hope it works for you:
That issue is unique to the scanner bulb not maintaining the proper temp, or warming up properly. Replacing the scanner assembly should fix the problem. Part# Q3948-67905
Jul 11, 2009 | HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
''No Cartridge'' Error
check if the cartridge is a hp cartridge
if no use a hp cartridge
if issue stll occurs
open the cartridge door
remove the cartridge and the papers from the tray
close the cartridge door and turn off the printer
then turn on then printer
you will get a msg install black cartridge
open the cartridge door and put the cartridge inside and the papers in the tray and close the cartridge door
the printer will intiallize and you will get a ready msg on the display of the printer.
if you still get the msg have the printer serviced
Feb 03, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
446 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
