Question about Nordic Track Recumbent Exercise Cycle GX4.0
How to remove crank arms from Nordictrack gx4.0
I heard a snap and the pedals don't move anymore. I want to open the front shield and se if I can fix the problem. I removed the caps and screws from the crank arms, but the arms won't come off.
5 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Need to remove Nordictrack 1500
Watch this videos:
http://www.youtube.com/watch?v=zXeHMWTcLUY
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
Posted on Nov 08, 2011
ercupa190
  • 12223 Answers
SOURCE: My nordictrack 1000 turns on, but the track does not move?
1) Check the sensor reed switch see the diagram by 1/8"
2) use the calibration software for easy diagnostic and fix it. see your owner manual and go under the hood for instruction step.
3) exchange the battery by new ones for console.
4) Measure the input 115vac for motor without load
5 Test the main motor board for output +5vdc for Display board.
See the block diagram for easy diagnostic that I did designed for quicly adjusting and fix it.
Sincerely Merry Christmas,.
ernesto cuadra
managua, nicaragua. c.a
12_24_2011_6_16_18_pm.gif12_24_2011_6_16_37_pm.gifhttp://www.fixya.com/support/r10786838-test_procedure_dc_motor
see my tips
Posted on Dec 24, 2011
ercupa190
  • 12223 Answers
SOURCE: How do I fix my Nordictrack Elite 7500? The incline is stuck and won't move up or down.
1) Lube the elevation motor, see the diagram, parts gear + shift
2) adjust the POT, for a little and see if there are better improve.
3) RUN the software calibration for diagnose, troubleshooting, fix it.
God bless you
Posted on Jul 10, 2012
ercupa190
  • 12223 Answers
SOURCE: Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Posted on Nov 19, 2012
Can't remove right pedal shield
The shield will not come off unless you remove the entire crank, not just the pedal. to do this, you need to buy a CRANK ARM PULLER TOOL available for around $15.oo at any bicycle shop. Make sure to get one for a square tapered bottom bracket. Just used one, the crank came right off and the shield simply lifted away. here is a link to a YouTube Video showing the tool and explaining the process: https://www.youtube.com/watch?v=N63ofGcRCYQ
Jan 28, 2014 | Nordic Track NordicTrack GX 5.0 Pro...
Tension to tight on bike won't losen
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use
Jan 04, 2013 | Weslo Pursuit R 3.8 Upright Exerise Bike...
Console 1
Nov 18, 2012 | Nordic Track Nordictrack Ack Asr 630...
Bremshey (Tunturi) Orbit Control S elliptical belt alignment
Dear Si: Please do the following>
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Remove the bolts connecting the swing arms to theelliptical's upright. Detach the swing arms from the upright, then spread alayer of machine grease over the axles on the upright. Reattach the arms to theupright.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
Nordictrack audiorider r400 checksum fail
Finally tight the flexible cord form keypanel vs display board and then tight the display board vs lower board.
See if you can meassure +5VDC from lower board to display board.
see the block diagram for your final diagnostic.
12_19_2011_5_43_08_pm.gifSincerely. Merry Christmas.
Ernesto cuadra
managua,nicaragua. c.a.
Dec 19, 2011 | Nordic Track Exercise & Fitness
I have a NordicTrack SL710 recumbant bike that the pedals slip and make a clicking noise?
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
Recumbant bike slips while peddling
http://www.youtube.com/watch?v=mVJxs7ALxDM&feature=related
Loose Pedals 1
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm.
Oct 30, 2011 | Nordic Track NordicTrack Treadmill, A2550
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Pedal is off center & scraping side
Hello there. What has more than likely happened is that one of your crank arms have come loose. The front covers to access the crank arms are removeable but difficult to do. There are 11 screws and three clips that hold the covers on each side. You will also need an 8 inch phillips head screw driver to remove the covers.
First remove power to the machine.
Second, Using the 8 inch screw driver remove the screw in the hole that is visible on the side of the unit.
Then remove the screw in the hole located just above the arm assembly
Another screw is located inside the cup holder remove that as well
after removing the screw in the cup holder you can lift the cup holder up slightly and access the two screws for the lower cover. There is also another screw under the cupholder holding the side shield on remove that as well.
Next go to the bottom of the lower cover. There will be two screws holding the lower part of the cover on. There are clips on each side of the cover which also connect it to the side shields. If you pull gently on the sides of the cover it will pop off. Only three more screws to go.
If you have the ability to tilt the machine on its side it will help in this step. There are three screws also holding the bottom of the side shield on. remove those as well.
The only thing holding the cover on now are three clips in the front of the machine. These will be difficult to remove! You have to partially seperate the two shields from the top and working your way down pull the two shields away from each other. They will make a loud noise when they come loose so beware.
Once you have gotten the cover loose you can raise it up over the arm assembly.
You can now start working on the original problem.
Once inside you need to locate the crank arm assembly. (this is where the pedal leg connects ) You will see a bolt going through the crank arm where it connects to the crank shaft. both the right and left crank arms should be flush with the crank shaft. To realign the arms you must loosen the bolt holding the crank arm and also loosen the allen screw holding the locating key in place. The arm should then be movable to a point where it can be tapped back flush with the crank shaft. Retighten the bolt loosened in the previous step first. Then retighten the locating key allan screw Be sure to use alot of pressure when tightening the crank bolts to be sure you will not have to do this again.
Reverse the procedure for the covers to reinstall them.
Good Luck! Tim
Dec 20, 2009 | Reebok Exercise & Fitness
Nordic Track Recumbent Exercise Cycle GX4.0 Logo
176 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
