Question about Slendertone Flex Go Abdominal Toning System, 1 ea
After 5 minutes my slendertone belt turns itself off
I want to watch the get started video on The Flex Belt, How to get started.
Flex Belt - YouTube
? 8:16
https://www.youtube.com/watch?v=gBYvxDeb5VY
Jun 28, 2013 - Uploaded by flexbeltabbelt
We've created helpful videos that will walk you through the easy set-up process. It is very simple to set up The Flex Belt and only takes a couple of minutes... ... tips for awesome results and help you with any questions you may have. ... Getting Started with your Flex Belt - Duration: 8:08. by flexbeltabbelt ...
The Flex Belt video review - YouTube
Dec 08, 2015 | Slendertone Flex Pro Abdominal Muscle...
Slendertone will not switch on
The replacement batteries could be defective or installed incorrectly. Also, the switch may have failed.
Apr 01, 2014 | Slendertone System Abs
Slendertone keeps beeping
the beeping its becouse there is no contact between the pads and the skin (1), or the cables and the pads (2), or the cables and the controller (3).
what the manufacturer says:
try to change the pads by new ones
i did that, but still not working.
what i do:
i had the second problem, but i fix it, i cut the cloth in the back part of the pin (not in the front of the pin), and i discover that the cable that is attached to the pin was cut, i remove the the pin, then i replaced with a bolt, i attch the cable to the bolt and thats all.
i'm using it right now and its works great.
i answer on another post similar to this one, a put a link to my google account where you can see pictures of what i did.
thums up! thank you!
Dec 28, 2013 | Slendertone Fortex
Error e002 slendertone flex belt
Dear Karen! I have the same problem white my slendertone e002 error,if you deal whit it,please helm me!
Oct 24, 2012 | Slendertone Abdominal Muscle Toner
My slendertone wont turn on. it did and i turned it off!! and when i went to turn it back on it wouldnt turn back on and i have changed the baterys!!!
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
Aug 13, 2011 | Slendertone Fortex
Bought Slendertone Start but lost instructions so dont how to use.Would like the instructions for slendertone start
Manuals for the various Slendertone products can be found here:
https://www.slendertoneusa.com/t-manuals.aspx
There does not seem to be a manual specifically designated for 'Slendertone Start'; is that a specific product or a program for using one or more of the Sendertone products?
May 21, 2011 | Health & Beauty
My slendertone belt keeps beeping with a triangle next to it. I can't turn up the intensity and it won't vibrate but I'm not sure why. What's the problem?
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
Feb 18, 2011 | Slendertone Fortex
How do you work the Slendertone Belt? I lost the
hold it in front of you comfortably and pull outward (its pretty straight forward)
Jan 13, 2010 | Slendertone Fortex
Belt slipping / takes a minute to start tumbling
Before replacing belt check the space between the drum and the front AND rear seals with your fingers for foreign objects caught there. This may make the drum too tight to turn. Belt is usually broken before it needs replacing.
Also check idler pulley next to motor and motor itself with belt off both pulleys making sure they both turn freely. I think something is binding. Check all those BEFORE replacing belt.
Disconnect plug before opening unit.
Aug 21, 2009 | Maytag Dryers
Slendertone Flex Go Abdominal Toning System, 1 ea Logo
66 people viewed this question
Top Slendertone Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
