Error 38 on billcon n-132 - Office Equipment & Supplies
Canon ixus 132 HD gives error e 32. how do i repare it?
Error codes in the 30 range usually point to a shutter problem. Looks like a repair job
Mar 02, 2015 | Canon IXUS 132 16 Megapixel Compact Camera...
NNeed torque specs for 2010 harley ultara classic, front axle nut, front brake calipers, axle nut holder
Front Axle = 60 to 65 foot pounds
Front caliper banjo bolts = 17 to 19 foot pounds
Front Brake disk screws = 16 to 29 foot pounds
Front caliper mounting bolts = 28 to 38 foot pounds
Front axle holder nuts = 132 to 180 inch pounds
Aug 23, 2014 | 2010 Harley Davidson FLHTCUTG Tri Glide...
Harley torque specs
axel nut.......50-55 ft-lbs
axel holder nuts......132-180 inch-pounds
lower mounting bolt...28-38 ft-lbs
Jul 19, 2014 | Harley Davidson FLHX Street Glide...
What should I do when the Display says Service call 132:Error
After turning ON the
power or when cover
is closed, the sensor
detects that the unit is
missing.
1) Is an Error message displayed?
2) Is the LED head properly
mounted?
3) Does the Error take place
again?
Confirm that the lever is in
position.
Replace the toner feed unit.
Replace the ID units.
May 27, 2014 | OKI C5100n Laser Printer
How to fix error 7a on a billcon d-551
I know this is an old post. But the Error 7A on a model D-551 is a "Gate Up" problem. The gate is what diverts the note to the reject pocket or the lower stacker area. 1) Check that the gate flap can be moved smoothly. The solenoid that electrically moves the gate flap is connected on the main control board (under the right cover) at CN14. Re-seat the plug cable. Also clean ALL the count sensors inside the machine. Good luck
May 14, 2014 | Billcon D-551 Mixed Money Counter 2 Pocket
ERROR E38
Found manual here with all error codes. It's in Russian though..
http://www.rservice.by/files/manual/cassida/counters/Cassida%20Billcon%20N120%20User%20Manual%2028.11.2013.pdf
Mar 24, 2014 | Billcon N-131 Money Counter
E38 compteuse de billets billcon
you can call me in this number
0213770112960
Jan 05, 2013 | Cars & Trucks
Icq error 132
how can I fix the ICQ error 132?
Oct 24, 2011 | ICQ Computers & Internet
Changing the AC belt in a 1994 ford aspire. any diagrams or tips? How long should the job take?
Power Steering Pump
See Figures 9, 10, 11 and 12
  1. Remove the air cleaner intake tube and air cleaner assembly.
  2. Loosen the power steering pump bolt and the adjustment locknut. Make sure the belt is properly seated on the pulley before adjustment.
    1. Turn the adjustment bolt to set the belt tension.
    2. Use Rotunda offset belt tension gauge 021-0028A, or equivalent, and following the tool manufacturers instructions, adjust the belt to the following specifications:
      New belt: 110-132 lbs. (50-60 kg). Run the engine for 10 minutes, then readjust the tension to 110-132 lbs. (50-60 kg). Used belt: 95-110 lbs. (43-50 kg).
    3. Tighten the power steering pump bolt to 27-38 ft. lbs. (37-52 Nm).
    4. Tighten the adjustment locknut to 14-19 ft. lbs. (19-25 Nm).
    5. Install the air cleaner and intake tube.
May 06, 2011 | Ford Aspire Cars & Trucks
Error when installing Move data process :-132
try to use another grabbee i think there's something wrong with the connection... that's why it display an error message..
Apr 28, 2009 | Computers & Internet
130 people viewed this question
jasbo
jasbo
