Question about Canon PowerShot S400 / IXUS 400 Digital Camera
SD200 E18 Error
When i turn on my camera and switch it to capture a picture the lens moves a little bit as well as some grinding noises. it then beeps and shows E18 in the left bottom corner. i dont need to know why its screwed up, i already know, i just need to figure out how to fix it. so please help me. any information will help.
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Posted on Jul 24, 2007
Camera shuts off after E18 error code
You have most likely dropped the camera or banged it against something while the lens was out. This situation causes the brass pinion gear to shear teeth off the plastic ring gear on the Inner Lens Housing. It may also cause the guide pins to jump their track. If this is the case the repair bill usually exceeds the value of the camera and you are probably better off selling it for parts on eBay and getting a new higher resolution camera.
Dec 21, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
E18 on canon sd450
the gears might be damaged already for the lens that why its not moving anymore, you may need to contact the manufacturer for service center referral
Jul 25, 2009 | Canon IXUS V2 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
E 18 problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jul 22, 2008 | Canon PowerShot SD200 / IXUS 30 Digital...
E18 error pops up and to make it worse the screen is green and its making a lot of beeps
http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html
The better solution is to send it to Canon's service people.  They can fix he problem is the fixes at the above site won't work.
Mar 05, 2008 | Canon PowerShot A520 Digital Camera
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Canon PowerShot SD200 E18 Error
The "E18" error code indicates an error that involves the lens unit or lens cover. The grinding noise you hear-to my regret- means that len's mechanism is malfunction. This type of problem could be fixed by professional only.
Jun 23, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Problem with E18
The "E18" error code indicates an error that involves the lens unit or lens cover. Or it may appear if you apply pressure to the area surrounding the lens while handling the camera. Remove and reinsert the batteries to see if the error code will reset. Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it
Oct 02, 2006 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
