Question about Acer Computers & Internet
When i connect a removable disk to my lap,all the files in the are change to hidden files
  • 76 Answers
Your computer are infected with virus. try scan your computer with a potent anti-virus this may help. however if you are sure that your pc is virus free then you can do this command here:
http://wraptnotes.com/2009/04/03/how-to-unhide-hidden-files-caused-by-a-virus/
may this help
Posted on Dec 30, 2012
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
it seems that correct network drivers are missing. Easiest way is to download the drivers from manufacturors site, transfer them with USB stick and install.
Sep 27, 2012 | Dell Dimension B110 PC Desktop
My SmartDisk FireLite external hard drive is showing 33 GB free out of 55 GB. I had all of my and my wife's files stored on it, but now it only shows all of our folders as shortcuts and says the item the...
I believe some virus caught your computer. If you can't find you're files try this.
-Go to that hard disk.
-In the menu bar look for tools.
-Folder option
-In the folder option window click view
-look for hidden files and folders
-In the 2 radio buttons click show hidden files and folders
-click apply.
If this is correct there is a way to remove those hidden things.
-Select the file or folder you wish to not hide.
-right click and look for properties
-unchecked hidden files and apply
hope this helps. Thank you for using Fixya!
Apr 19, 2011 | SmartDisk FireLite 80 GB Hard Drive
Can't get my lap top to open the bl--dy thing Lap top see's it but won't open it up can any one help before i put a hammer to it i've had it for about 2yrs now but haven't been able to access it now for at...
Try to connect the external disk-drive to a different computer.
If you still cannot access any files, then either:
* the USB-to-disk-drive adapter inside the case is malfunctioning,
* the disk-drive inside the case is malfunctioning.
Read the serial-number of the external disk-drive from the case, and access the manufacturer's web-site, and check to see if the "warranty" for the device is still available. If so, the manufacturer will replace the device -- you might have to pay "shipping" to send your device to them.
If the warranty has expired, open the case, remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer, to see if the USB-to-disk-drive device was the problem.
While the case is open, you could purchase a new disk-drive to fit into the case, and then close the case, and once again have a working "external" disk-drive.
Aug 16, 2010 | LaCie (300770) 250 GB Hard Drive
My Psp still have it's contents but when i connect it to my PC and oepn it as a Removable Disk. There appears nothing. When i explore and go to TOOLS - Folder Options - Show all Hidden Files. There only...
Maybe the drive is partitioned into 2 or 3 partitions and only one is visible.
Try going into START -CONTROL PANEL - ADMINISTRATIVE TOOLS - STORAGE and see what drives show up there. You may be able to assign a hidden drive a letter from there and it will be visible. NB Watch out though because changing the drive permanently may mean it wont work in the PSPwhen you put it back.
Mar 07, 2010 | Sony ACY-BR81/OB
Rootkit
Hello,first try to find the driver from device manager(right click to my computer,properties,hardware,device manager).Once you have open the device manager press on View and check Show hidden devices,your driver(virus) is on non plug and play drivers and with right click you can unistall it.But if is a root kid and a tought one it should have another file in your system to recreate it!So clean your windows temp files and internet temporary internet files(you can with a application or just right click to your disk,properties and click disk clenup).If you still can fix it
download HijackThis and in the main menu press do a system scan and save logfile.After open your logfile and give me the results
Good luck
Jan 22, 2010 | Internet Grisoft AVG Security Full...
There are several songs that are on the m240 that are not showing when you look at it's files - how are these hidden?
If you added songs to the device in MSC mode, then switch to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching from MSC to MTP mode or vice versa.
For older players - e200v1, c200v1, c100, m200 - the files become hidden files if the modes are switched. An easy workaround is to edit the folder options to show hidden files.
STEP 1 - Edit the folder options of the computer to show the hidden files
Windows XP:
1. Double-click My Computer.
2. Under the Tools menu, select Folder options, then click the View tab.
3. Under Hidden files and folders option, select Show hidden files and folders.
4. Uncheck the Hide protected operating system files (Recommended) check box.
5. Click Apply, then click OK.
Windows Vista:
1. Double-click Computer.
2. Click the Organize button on the upper left corner.
3. Click Folder and search options.
4. Click the View tab and select Show hidden files and folders.
5. Uncheck the Hide protected operating system files check box.
6. Click Apply, then click OK.
SOLUTION 2 - Perform a Check Disk.
STEP 1 - Switch to MSC mode
1. On your Sansa player, switch the USB mode to MSC.
2. Connect the Sansa player to the PC.
STEP 2 - Perform Check Disk
1. Locate the Sansa player under My Computer.
2. Right-click the removable drive associated with the Sansa player, and select Properties.
3. Click the Tools tab, and then click Check now.
4. Click to select the Automatically fix the file system errors and Scan for and attempt recovery of bad sectors check boxes.
5. Click Start.
See also this tip on what it all means http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
Jan 02, 2010 | SanDisk Sansa m240 MP3 Player
My computer recognizes that I have 1.8 GB left on the disk but when I try to download songs it claims that the disk if full. What do I do?
Good day sir/maam, hi, your SD card may be infected by a virus that wont allow anymore software or files to be stored on the disk, run a virus scan on your PC, there is an easy way to check if your PC is infected, to check, on the my computer menu bar click tools, folder options, view, select show hidden files and folder, then apply, close the window, Now go back to the folder option, view and check the show hidden files, its changed. and goes back to not show hidden files. If this happens, download AVG anti virus and scan your computer.
Nov 17, 2009 | SanDisk 2GB microSD Memory Card
ACER 1360
Unless I am mistaken, the D drive or partition is the partition that contains the restore feature for yor laptop. This may or may not be hidden system files. As far as the available free space on your C drive, you WILL need to either delete files and/or backup and delete files. Image files, music files, cookies temp files take up a lot of disk space. Try this and I think you will find more free space. BPCS
Dec 23, 2007 | Acer Aspire 1360 Notebook
Mp3 files not being deleted from player
First change the setting of the player to MSC (SETTINGS>USB MODE>MSC) then connect the player to the computer. Open My Computer window and you should see the player right-click on the player and choose format. Click start to continue formatting the player and it should erase all the files in the player. :D
Jul 07, 2007 | SanDisk Sansa m230 MP3 Player
Computers & Internet Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
