Question about Tools & Hardware - Others
I just bought a huskee 28 ton log splitter which came assembled and after it flooding several times got started it was wide open . I was wondering if govenor or carberator has a adjustment or was assembeled wtong
3 Suggested Answers
  • 1015 Answers
SOURCE: i have a 4052 mcCulloch
Not having a mcCULLOCH manual I dont know what they reccomend,but on mine I just use HI grade industrial/commercial hydraulic fluid. I have been using this for 15 years and have had no trouble. I change oil and filter every year. Thank you.
Posted on Nov 06, 2010
  • 65 Answers
SOURCE: my hydraulic system on my 22 ton huskee log splitter stoped working
check oil level first.
Posted on Nov 21, 2012
I have a 28 ton Huskee log splitter with a honda engine that isnt gettin gas even though there is gas in it. What do i do to get it running?
Find out why it is getting no gas!
First check the tank, does really have gas in it? Use a dipstick.
Check the fuel tap. Remove the gas line, does gas come from the tank? Re-attach the line.
Remove the gas line from the carburettor, does gas come from the pipe? Re-attach.
If the fuel is getting that far, then it has to be the float stuck in the carb. Give it a sharp tap with the handle of a hammer.
Still no gas? How do you know? Remove the spark plug, is the plug wet or dry? If it is wet, you have gas to the engine, but it won't start. That could be dirty or wet plugs, or an electrical fault to the ignition system. We can go on from there, when you have done all the above.
Dec 28, 2016 | Tools & Hardware - Others
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
My log splitter wont stay running, gas getting to carb and thats as far as it goes. It does start ann runs till primer is empty. The splitter is 2 yrs old. Can you help please?
I suspect that the main jet in the carby is blocked
It could be that the needle in the carby is stuck closed
There could be water in the carby
I would pull the carby and have it overhauled / cleaned out
Oct 03, 2015 | Tools & Hardware - Others
How do I change the seal in a 22 ton Huskee log splitter?
Picture of the cylinder my help, I have had different hydraulic cylinders apart. I don't know which one they put on a Huskee.
Feb 27, 2015 | Cars & Trucks
My 22 ton Huskee log splitter hydraulics quit working, I checked the fluid, that is fine, what next?
Its only a guess but see if its sheared the drive key between the motor and pump.
Dec 27, 2014 | Heavy Machinery
I have a honda gc190 motor in my Husky 28 ton log splitter everytime I start it it pours fuel from the carborator does anyone know why
The needle valve and float are stuck inside carburetor. You will have to remove the fuel bowl under carburetor and see if there is something keeping the needle valve from seating. GOOD LUCK FRIEND.
Nov 30, 2014 | Honda Cars & Trucks
Splitter runs through the cycle too slow
Make sure you hydrolic fluid tank has the proper amount of fluid.
Sep 11, 2014 | Swisher 28 Ton 11.5 HP Log Splitter -...
What type of motor oil do I use in my Huskee 22 ton log splitter?
If you are using it mainly at 30 degrees or above I would use straight 30 weight non-detergent oil.If you use it at lower temperatures then I would use 10w-30.That's what I run in mine and it's running great after 16 years. Thank you.
Jul 28, 2011 | Garden
Tools & Hardware - Others Logo
29 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
