Question about Curtis-Mathis Televison & Video
Diagrama curtis-mathis tv modelo . cm27101s
Mexico enzanblado
3 Suggested Answers
joboo1
  • 257 Answers
SOURCE: SCREEN SIZE
Hi, As indicated by your model number the screen size is 27 inch, which is a common diagonal measurement. This TV has a standard aspect ratio of 4:3.
Posted on Jan 29, 2009
maatmartin7
  • 1212 Answers
SOURCE: cuales son los codigos para ajustar la imagen de
You have bad capacitors near the vertical IC. And you might have some one change the two horizontal caps as well. One is 250volts 2.2MF and the other is a 25volt 47MF. The caps near the vertical would include a 35 volt 100MF, two 50 volts 100MF, 50 volt .1MF, 16 volt 100MF and a 50 volt 10MF. If the fuse in your TV is good...you will not have to change any semi conductors [ICs].
Posted on Feb 01, 2010
Testimonial: "gracias si me sirvio su ayuda el condensador dañdo fue el de .1mf 50 voltios. gracias otra vez."
I have a curtis mathes model plef398ccd how much would it cost to buy this T.V.
$50 work great but frame cosmatic don't look that great.$75 buck,if still in exellent conditions as tv work and vey good condition cosmatic looking frame.
Aug 31, 2011 | Curtis-Mathis CM27101S TV
Nedd to reset TV manually...... remote is not working
I have a curtis Mathis model number cm19102 . I have no remote. It is stuck on no more than 14 channels. Then the word line comes up on blank screen. How can I get it to get more channels
Jul 17, 2010 | Curtis-Mathis CM27101S TV
Curtis mathis tv takes to for picture to show after turning on
Look for a bad caps 250volt 2.2MF and a 25 volt 47MF near the horizontal deflection! And you may as well check the caps near the vertical IC as these are going bad...you have board out..you may as well do this. Then you will have a reconditoned TV with added years!
Feb 19, 2010 | Curtis-Mathis CM27101S TV
I have a curtis mathes/tronics tv Made in May/2001 Serial no#CM19022S I am trying to hook up a digital conventer box to it and I am having troubles. I also need a users manual for this model and year, pls...
No need for the tv manual.Just follow the basic hook up instructions in the booklet came in with the Converter box.Very easy use channel 3.Use the codes for Curtis-Mathis tv in the booklet for the remote.I hook this Exact model of tv is take 20 mins.
Feb 17, 2010 | Curtis-Mathis CM27101S TV
Cuales son los codigos para ajustar la imagen de
Feb 01, 2010 | Curtis-Mathis CM27101S TV
Trying to connect a wii to my curtis mathis tv and we can not figure out how to set the tv on aux with a universal remote
Theres Either Gonna Be A Tv/Video Button On The Remote Or The Tv. Also Try Going To Channel 01 And Then Going Down A Channel To See If You Can Access The Aux Function That Way.
Jan 30, 2009 | Curtis-Mathis CM27101S TV
SCREEN SIZE
Jan 29, 2009 | Curtis-Mathis CM27101S TV
Curtis mathis tv
the Fly-back transformer is bad, it's arcing "ticking sound" it needs repair get estimate first because it might not be worth repairing depending on the cost of the transformer and labor
Hope this helps
thanks for the rating
Jan 08, 2008 | Curtis-Mathis CM27101S TV
Curtis-Mathis C-2620RC
I would suspect that most A.C. cords could work for this TV. It should be soldered to the main board and not plug in. If you do replace it you need to make sure the polarization is done correctly or a shock hazzard could be present!
Apr 19, 2007 | Curtis-Mathis CM27101S TV
Televison & Video Logo
20 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
