I can't get the captions on my sansui tvs2746a and i don't have a remote and i can't find it in the menu options
I can't get the captions off the television and i don't have a remote nor can i find it in the menu. can someone plz help me?
    Top Expert:
  • Televison & ... Master
  • 74,245 Answers
To select this option, you must have its remote control.
Posted on Dec 30, 2012
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
SOURCE: Turning off the closed captioning without the remote.
I had the same problem. I got a Philips Magnavox Universal Remote that has a closed captioning button [CC]. Here's a link to the same type:
http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1240350929&sr=8-1
Posted on Apr 21, 2009
  • 3 Answers
SOURCE: can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
Posted on May 17, 2009
  • 176 Answers
SOURCE: Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
Posted on Jan 05, 2010
  • 8457 Answers
SOURCE: How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Posted on Feb 08, 2010
Sansui tvs2746 how to turn on closed captioning
If its remote control have a button marked "CC", pressing it once should make the Closed caption out. Pressing it again, the closed caption will re-appear. It will work like a toggle switch.
If there is no such button on the remote control, you have to surf its menu options, to find out the closed caption option, and there you will have access to turn it On/Off. Refer its user manual for more details. Gopakumar Gopalan Google
May 20, 2014 | Televison & Video
Philips 24PT6341 closed captioning won't turn off and there is no option in menu
There must be a button marked "CC" on your TVs remote control. Press it once. It will make the closed caption windwow off.
Jun 21, 2012 | Philips 27PT6441 27" TV
Can't turn on memorex MT2012 Closed Captioning using a universal remote
You must have its original remote control, which will have 'CC; button on it. you have to press this button once to cancel the Closed Caption option. If you can acccess the Menu of the tV by your present universal remote contro,; get into TVs Menu option, surf through, come to closed capation adjust window, and cancell [OFF] the closed caption option.
Apr 08, 2012 | Televison & Video
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
I have a Toshiba 27AF45 and a RC64 remote control which is not what comes with the TV. It works ok but I cannot figure out how to turn on the closed captioning feature. When I enable the menu I do not see...
Unfortunately, TVs don't always work with universal remotes. The original remote probably had a button to control the captions, and there may not be any other way to access those settings. If you can't find caption control settings using the on-screen menu, you are out of luck. The only options then are to try another brand or model of universal remote that may have a button which will work, or to locate a replacement original remote control.
Jun 21, 2011 | Toshiba 27AF45 27" TV
I have an older model sansui tv with out original remote. Somehow captions were turned on and I can't figure out how to turn them off. Help asap!
Ur tv have a button that said Menu on the bottom tv beside buttons only said POWER,CHANNELS + -,VOLUME + - ?Used the tv menu button go through the options functions look for Close Caption find CC 1,2,3 or TEXT 1,2,3 turn it all off,will stop captionning,if tv have no Menu option button.The captionning can be turn off by an original remote only.Try website like Remotes.com to buy the tv original remote.
Apr 27, 2011 | Televison & Video
How do I shut off the captioned dialogue on the screen for my magnavox smart series tv. there seems to be no such choice on the menu
hi,
For closing the Closed Caption option do the following.
1. Press the MENU button on the remote to see the menu.
2.Press the up arrow or down arrow until the CC (Close Caption) is highlighted.
3. Press the right arrow repeatedly until CC OFF appears.
4 .Press the menu button to exit.
Or, you also can set Closed Captions by pressing the CC button on the remote. Press CC repeatedly to select: CC-OFF,
ok
Feb 07, 2011 | Philips Magnavox 20MS233S 20" TV
Sansui (orion) TVS2746A. Help! volumn down + 8 killed it
Looking for horizontal transformer for samsui mod tv2746a
fjn27a003 . Do you have it? if is like this , tell me the price pleasse.
thanks.
latinotvrepair@live.com
Nov 11, 2009 | Televison & Video
Black Box On Screen
Salutations Cranberries,
The annoying black box is usually a feature of the closed captioning called "Text" You should be able to go in to onscreen menu and select caption options. Unless you need to have the closed captioning on for medical reasons, it maybe best just to turn off all captioning options.
Hope this helps.
Jon
Go Ahead. Use Us.
May 27, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
