Need a wiring diagram for a reznor us125f heater ?
Looking for a wiring diagram for a reznor us125f heater ?
  • 6 more comments
  • Michael Hamrick
    Michael Hamrick Dec 30, 2012
    can't get the website to connect www.rezspec.com
  • kelldogg40
    kelldogg40 Dec 30, 2012
    NIETHER COULD I. TRY AGAIN LATER I SUPPOSE. WHAT'S THE PROBLEM WITH REZNOR? WILL IT HEAT?
  • Michael Hamrick
    I think I dont have it wired right . The fan blows and the pilot light lights thats about it ./
  • kelldogg40
    SORRY. I'VE BEEN ADDRESSING SO MANY PROBLEMS I FORGOT WHAT YOUR'S WAS, YOUR PILOT WOULD NOT STAY LIT CORRECT? THE THERMOCOUPLE IS WHAT SENSES THE FLAME OF THE PILOT, THEREFORE TELLING THE GAS VALVE TO OPEN SENDING THE PROPER AMOUNT OF GAS AT THE CORRECT PRESSURE IN TURN FIRING OFF THE BURNERS. IT WON'T CAUSE THE PILOT NOT TO STAY LIT. IF THE PILOT ASSEMBLY APPEARS TO BE IN GOOD CONDITION, & FREE FROM OBSTRUCTIONS, WHEN LIT THE FLAME OF PILOT SHOULD ENGULF THE THERMOCOUPLE IF NOT THERE MUST BE SOMETHING PARTIALLY BLOCKING THE PATH FROM THE GAS VALVE TO THE PILOT. ALSO IN RARE CASES THE TOP TO THE FLUE GOING OUT OF THE BUILDING COME OFF ALLOWING GUSTS OF AIR TO ENTER THROUGH THE EXHAUST PIPE BLOWING THE PILOT FLAME OUT. HOPE THAT HELPED, GOOD LUCK!
  • kelldogg40
    DO YOU MEAN THE DRAFT INDUCER MOTOR FOR THE EXHAUST, OR THE MAIN BLOWER MOTOR FOR AIR CIRCULATION?
  • Michael Hamrick
    the main blower works fine and the pilot lit is lit
  • kelldogg40
    THE MAIN BLOWER SHOULD NOT COME ON UNTIL THE MAIN BURNERS HAVE LIT. THE ONLY MOTOR THAT SHOULD BE RUNNING IS THE DRAFT INDUCER MOTOR, WICH IN TURN CLOSES THE PRESSURE SWITCH ALLOWING THE GAS VALVE TO OPEN UP FOR THE MAIN BURNERS. IF PRESSURE SWITCH DOESN'T OPEN IT WILL NEVER TRY TO FIRE UP.
  • Michael Hamrick
    Michael Hamrick Jan 01, 2013
    got a wiring diagram here
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
I'LL SEE WHAT I CAN FIND FOR YOU.
Posted on Dec 30, 2012
2 Suggested Answers
  • 79 Answers
SOURCE: need a manual for Reznor unit heater UA 40
Reznors website is: www.rezspec.com
go to their home page and click on the "manuals & media" tab. You will find the folders on that page for installation,parts,and servce manuals. After you find the manual you are looking for you can download it for free. Good luck!!
Posted on Nov 20, 2009
How to test thermo disc safety on reznor hanging heater
Brian, it is a very simple task to perform but for a novice YOU MUST HAVE THE POWER OFF !!!!!!
At Harbor Freight you can buy a cheap digital multimeter for about five bucks. After turning off the power, remove one wire from the thermodisc and use the resistance scale to check continuity. If it reads no continuity, the switch is OPEN and bad. If it reads continuity it is CLOSED and is good.
If you have a system that is not heating, did you check the top right side (facing the unit) of the Reznor heater for a 'manual reset' hi-limit switch ?? If not, do that first and listen for an audible 'click' as you depress the little red pushbutton. If you hear a click, turn the power back on and set the thermostat setpoint above room temperature and see if the heat now comes on.
Dec 02, 2015 | Heating & Cooling
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Smell gas in garage after reznor heater shuts off
sounds like the gas valve is leaking through.
have it checked out asap gas leaks only get bigger.
Feb 12, 2015 | Reznor Hanging Furnaces-Power Vented-...
Reznor Heater UEAS 260 not heating
Check your igniter. If the furnce does not light it will do that every time.
Dec 09, 2013 | Reznor 205895 CC2 Vertical Vent Kit for...
Reznor UDAP 100 tripping Flame Rollout Switch
If the flame is rolling out of the heater then the burners of heat exchanger is blocked needs cleaning
Feb 19, 2013 | Heating & Cooling
Wiring diagram reznor rdf1-65
The RDF1 installation manuals are here, they should have the wiring diagrams you need. Since each unit is almost a custom installation, this is the only reliable way to ensure the unit is wired correctly in your application.
https://www.rezspec.com/index.php?module=000000000012&pageid=000000000014&mod_files[currpos]=000000000029&mod_search[text]=RDF1&mod_search[skipsearch]=true
All lines need to be one one.
Should this be a pereishable URL, just enter "RDF1" into the site search window.
Their site map page which also has the installation manuals for all their units is:
https://www.rezspec.com/page-14_See_all_folders.html
Jan 17, 2012 | Cars & Trucks
Need a manual for Reznor unit heater UA 40
Nov 20, 2009 | Heating & Cooling
I have an old reznor model us-100f, the heater will run for approx. 10 min. before blower fan will start to run
Your fan switch is most likely bad. Need to replace.it with a new one. Not hard to replace just take old one to a AC supply house and they will match it. Or go on line to Reznor and they will have it, Just need the model number of unit. Rus
Nov 07, 2009 | Heating & Cooling
Reznor model# f125 pilot won't stay lit. i
Make sure the pilot is clean (Blue flame fully enveloping the top portion of the thermocouple) if its dirty the pilot will be yellow like a candle and barely touching the thermocouple ...quick fix is knock the pilot with a screwdriver...gently tapping it...knocking the dust out and getting a better pilot....the pilot could also be too small if its not making good contact with the thrermocouple....there could also be an Auxillary limit wired into the thermocouple which when open will prevent the magnet from staying closed....if all looks fine then the Gas Valve itself is likely gone (The magnet inside is not field repairable)
Oct 25, 2009 | Heating & Cooling
Heating & Cooling Logo
427 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
