Question about Euro-Pro Sewing Machines
How do i wind the bobbin on a touch tronic 2000
Winding the bobbin
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
  • 3 Answers
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
  • 371 Answers
SOURCE: bobbin won't wind
The bobbin rewind unit needs to be inspected. In order to do that the covers have to be removed. It could be the wiring to the board may be disconnected or the rewind unit is just broken and needs to be replaced. You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
  • 139 Answers
SOURCE: Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 16, 2010
  • 54 Answers
SOURCE: touch tronic 2005 by singer won't wind bobbin
bobbin case is out of adjustment
Posted on Aug 17, 2010
2001 Touch Tronic. Worked fine yesterday. Today, why can't I wind a bobbin?
If you haven't cleaned and oiled your machine recently, you might start there. Consult your owner's manual, use ONLY fresh, good quality sewing machine oil, and apply 1-2 drops of oil each spot specified in the manual.
If the machine bobbin winder is still not working, does it still sew? If so, you probably have two choices:
1) Take it in for service
2) Buy a standalone bobbin winder (~$30) from JoAnn's, Hancocks, or Amazon.com
If the machine does not sew, take it for service.
Dec 28, 2015 | Singer Sewing Machines
Winding bobbin athena 2000
I had one of these machines, they're Touch and Sew, and the bobbin winds in place. Check to make sure you actually have the correct bobbin inserted, because the bobbin it uses is available with a metal center post and without a center post, and yours takes the one without. I had another machine that took the center post one and accidentally put the wrong one in the 2000 one day and had the same problem.
Jul 10, 2014 | Singer Sewing Machines
Ishow me how to rewind the bobbin on a touch tronic 2001 singer sewing machine
Presser foot up, takeup lever at the top, thread the machine normally all the way and through the needle, open the needle plate, press the little lever to the right, wind the thread from the needle round the presser foot screw, press on the foot control slowly and wind the bobbin, when you have enough thread on the bobbin close the slide plate the winder will drop down, pull the threads to the back of the machine and start sewing
Oct 30, 2013 | Sewing Machines
Show me how to rewind bobbin for a singer sewing machine touch tronic 2001
You may source thru google or utube under bobbin winding for singer sewing machine video
I have a singer touch tronic sewing machine. I need to fill the bobbin and I cannot get it to work. where can I buy more bobbins that have already been filled to fit my machine
Has the bobbin winder worked in the past and now faulting. Or are you unsure on how to use it?
There is a manual for a Touchtronic 2000 here http://www.singerco.com/uploads/download/432_touchtronic.pdf there may be more than one model Touch Tronic so plse check the serial number plate on the side of your machine to establish the actual model number, usually near the power inlet plug. then search for the appropriate manual at http://www.singerco.com/accessories/instruction-manuals. This excerpt shows that you wind the bobbin insitu in the bobbin case.
I'm not a fan of prewound bobbins, far better to deal with the bobbin winder issue. Winding your own thread means you can get far better colour matching to the fabric, and ensure you've got quality thread on the machine, and same thread top and bottom. (I prefer a quality cotton wrapped polyester or a polyester thread, Guttermann, Molynecke or Sylko Supreme). All of these factors affect stitching quality and the finished appearance of a seam.
Did you know that you can buy a freestanding unit to wind bobbins? Link to this item is here. http://www.sewingpartsonline.com/universal-automatic-bobbin-winder.aspx You may well find that this is the better solution to winding bobbins for this machine as winding them inside the bobbin housing doesn't give you a lot of control over the way the thread feeds onto the bobbin.
Jun 27, 2011 | Sewing Machines
How do I rewind the bobbin on my singer touch tronic 2001? It was handed down to me without a manual.
you can go to www.tandtrepair.com and they show lots of free things for your machine, like winding the bobbin etc. Also, you can order a hard copy of your manual from Singer, 1-800-4singer for $15 or download one for $12 from www.sewingmanuals.com and pay through paypal. You have lots of choices. Good luck, Happy New Year
Jan 02, 2011 | Sewing Machines
Sewing Machines Logo
47 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
