Question about Krups XP 5280 Espresso Machine
How to clean krups xp5280
I found this packed away and want to clean it for healthiest safest o[eration
How do i test a coil pack on a 2003 Saturn ION 2.2 L engine?
Its not the safest way but, you take a long screw driver and stick it in to each spark plug boot(one at a time) and hold the metal shaft of the driver about 1/4 inch away from the engine block and have someone turn the motor over. Then, all you do is look for the spark. If you dont see it, the plug isnt getting spark.
Jan 24, 2015 | 2003 Saturn ION
How do i clean my stainless steel krups coffee maker before use model kt 611d50
Just run one full pot of cold water through it. Do not add coffee. Then it is ready for use. Caution - Do not make coffee right away because you can break the glass carafe by adding cold water to a hot carafe. Also the hot plate would be very hot too.
May 30, 2014 | Krups FME2 Coffee Maker
On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Oct 10, 2009 | Krups FME4 Coffee Maker
Krups xp4030 wont push espresso thru and when you
I had the same problem. The metal filter is clogged with very finely ground coffee. To clear the filter, boil it in vinegar and let it sit for a few hours. Rinse the filter and run water through it in the machine (no coffee in the filter). I found I had to grind the coffee at the medium setting in order to keep the problem from recurring.
Aug 05, 2009 | Krups XP4030 Espresso Machine
Would like to install a water filter
Add a in-line filter to the incoming water line behind the refrigerator.
Most have 1/4 inch compression fittings to adapt.
Mar 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups XP 5280 Espresso Machine Logo
94 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
