Question about Kitchen Ranges
Electric ovens with thermostat knob that get hard to turn
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have had a number of Chef (now Electrolux) stoves where over time the thermostat get hard to turn. If left it eventually causes the knob to break due to the excessive pressure.
Initially I purchased new knobs though these failed not long afterwards. For the first oven I glued the knob on though again this eventually failed due to the stiffness. I also broke the sintered brass shaft trying to enlarge the split in the shaft. I even purchased a new thermostat.
As a last ditched effort prior to replacing the thermostat I decided that it could be the shaft binding on the inner collar. If this was the case then simply lubricating the shaft to the collar should work. I removed the knob and using WD-40 with the extension tube sprayed a small amount between the shaft and the collar. This within one or two turns had completely corrected the stiffness. Use of CRC 2-26 would most likely also corrected the problem.
I have since this time corrected another 10 ovens with the same type of fault.
If this corrects you problem mail me as I am interested in how many types of ovens have the same problem.
  • 1 more comment
  • ikrichard Jan 18, 2009
    The solution to this problem is as posted in the detailed description
  • kbsw923 Jan 19, 2009
    I also started having this problem with a Tappan Gas Range. I'd like to try your lubricating method prior to purchasing a nearly $50 thermostat. Could you explain where to oil (shaft and collar?)? I'll let you know how i make out after I give it a try. Thx for the tip!
  • ikrichard Jan 24, 2009
    After removing the knob in my case there is a sintered brass shaft with a brass collar, both CRC and WD-40 come with an extension tube which can be connected to the nozel of the can. Simply apply a small amount between the shaft and the collar, where they meet. The presure from the can will be sufficient to force enough lubricant down the gap between the shaft and the collar to do the trick.
The solution is actualy contained in the description. Using CRC or WD-40 it is possible to lubricate it brass singered shaft which is where the actual binding occurs.
Posted on Jan 24, 2009
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Replacement Knobs for 60's Universal Chef- Waste King Universal
I have an old Universal Chef stove - we are replacing - it is probably a mid to late 60's - the oven pan is warped - otherwise it works fine - burners, knobs, grates etc. are good - willing to let go cheap - contact Chester Koch 573-898-5508 (Elsberry, MO)
Apr 24, 2009 | Cooktops
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 | Ovens
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Hi - Please post the model number of you appliance, it will look something like CEC1536.
Jul 02, 2008 | Magic Chef 9512 Electric Single Oven
Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
Feb 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
153 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
