Question about Kenmore 57029 Side by Side Refrigerator
WHIRLPOOL side by side freezer works fine but frig warm
Freezer good but not enough air flowing into frig side.It's empty o vents aren't blocked.
Thanks Rick
  • 979 Answers
There is something in the path of the vent. Either some ice or debris.
Posted on Feb 25, 2009
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a kitchenaid, KSRS25RSMS01, refrigerator and the freezer is fine and the fridge is not cooling. I have checked the evaporator and it has normal frost, and the fan is turning fine, but the air coming...
Your frig has the classic symptoms of a frig with a clogged or blocked vent between the
freezer section and the refrigerated section. This clog can occur due to (a) stuff in the freezer blocking the vent, or (b) ice in the freezer blocking the vent, or (c) both of the above.
The way a refrigerator works is it cools the freezer, and the warmest air in the freezer is vented out
to the refrigerator section. If this vent is blocked (and everything else is working), your refrigerator
just became a eye-level small freezer atop a well-insulated section of dangerously warm food.
May 13, 2011 | Refrigerators
My refrigeraer has the freezer on top. the freezer is working fine but the bottom part does not get cold enough. i would like to know if it needs a part or if it ready to discard thank you. my email...
There should be a fan that blows air from the freezer compartment to the refrigerator side. Check to see if you can hear the fan or feel air coming from the vent. Also if the defrost is not working properly ice formation can block the air flow on some models. Also make sure the vent between the 2 compartments isn't blocked.
Dec 28, 2010 | Whirlpool ED2FHSS Side by Side...
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Whirlpool side by side - freezer is fine. Fridge not cold
This is a common problem, and worth fixing if the frig isn't to old. The frig is making cold air just fine, which is a plus! All we need to do is get that air to circulate throughout the entire appliance.
Behind the freezer wall is a fan called an evaporator fan. This fan simply blows the air straight up the back of the freezer. From here it enters the frig at the top left and sinks to the bottom. Then it re-enters the freezer and continues its loop :D
So, either the circulation is being obstructed by something (maybe ice build up), or the fan is out.
Behind the freezer wall is the evaporator fan (that has probably stopped moving). Either ice build up (or some obstruction) has stopped it, or it has just served its time and needs to be replaced. Generally I would just replace it. You never know if it has been damaged from ice blockage or whatever the problem may be. If the motor is trying to spin and it is being held in place, bearing could be wearing out or completely gone which will just cause you more pain in the near future. So replace that puppy and you should be all set! :D good luck!
P.S. Naturally, if the fan is fine but you have something blocking the air flow, just fix the air flow problem in an apppropriate manor :)
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Line and air flow box between freezer and frig freezing up, we took apart, defrosted . air comes into frig, but still not cool enough. freezer works great This is a side by side model # ED25PWXAN01
If the fan is running in the freezer compartment, temperatiure is normal, and no frost is building up on the back panel in the freezer panel, then there is a good chance the return air shutes in the fresh food compartment are blocked with ice. The return ducting is just as important as the the supply shute which you melted out. Difficult if not impossible to see.
My recomendation is to empty, unplug and air dry the whole machine preferably with a fan blowing air into the fresh food compartment.
Haste makes waste with this machine. Using heat can cause the plastic shutes to melt and distort.
Should be defrosted in this manner for 24 hours.
Restart and give the machine 24 hours to recover. Common problem with Whirlpool products.
P.S. Check to see if lights go out when closing fridge door. In fact this should be your first step. Jack
Nov 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice in frig air vent
you did just fine defrosting it but, when you put everything back in don't overpack it, leave room for the air to circulate. the heat from the bottom unit will cause enough condensation to leak down the air vent and the it will refreeze blocking your vent again
Jul 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Freezer side working fine. Refrigerated side very
Sounds like circulation fan for frig is fr worn out.May be able to take of and free up my manually turning and lubricate around shaft with 3 in one oil.
Jun 18, 2009 | Maytag MSD2458G Side by Side Refrigerator
You may think the freezer is fine, but stick a thermometer in to be sure. It should be around 0 degrees F. If not, you may have iced up coils. See some other posts on this site about getting to those coils and defrosting.
Jan 20, 2009 | Jenn-Air JCD2389G Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
