Question about Soyo SYXRT4791AB 47 in. LCD TV
Keypads locked need code to unlock them - Soyo SYXRT4791AB 47 in. LCD TV
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: unlock keypads to a Soyo SYXRT4791AB 47 In. LCD TV
Not a solution but a suggestion, the 43 page user manual if you have it or can find it (I looked and saw only a reference to it being 43 pages) will almost certainly have the information on how to unlock the keyboard, find that and you should be able to unlock it.
Posted on Dec 18, 2012
I need keypad unlock code for samsung behold it locked when I was trying to unlock the network.
There is no specific keypad unlock code my friend, are you sure you have correct samsung behold network unlock code? Actually if your phone already unlocked with correct samsung unlock code that problem will not happened. My sugestion check your unlock code, if your unlock code is the right one you need to reflash your phone.
Aug 14, 2011 | Samsung Behold Cell Phone
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
How can I lock the keypad?
Keypad lock: To lock the keypad press Menu then Star (*) key. To unlock the keypad press Unlock (Menu key) then Star (*) key. Press both keys in a fast way.
Hope this help and if helpful RATE please
Feb 22, 2011 | Nokia 6310i
I forgot my unlock code for my verizon phone
To Unlock the Verizon Network Locked Mobile from the security or Password lock You can use the Master Reset Code,You can get the Master Reset Code here
http://www.superunlockcodes.com/unlocking-services/rs12wp6/ and Unlock it from the security lock.
Dec 06, 2010 | Cell Phones
How unlock my nokia keypad .it's 1100 nokia mobile. I can't remember keypad unlock code
keypad can be locked using the security code .... security lock can be reset using master unlock code ...
you can get the master unlock code at www.theunlockspot.com ... in reliable cost
Nov 12, 2010 | Nokia 1100
How to change the keypad code on a 2001 mercury grand marquis
look for the permanent code on the plastic card in the owner manual packet. Or, pay dealer to extract code from computer.
Keyless Entry Keypad Code Programming NOTE: The system only allows one code to be programmed.
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code . The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
  1. Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
Feb 08, 2010 | 2001 Mercury Grand Marquis
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
How to lock the keypad with security code for sony ericsson?
I DONT WANT THE AUTOMATIC KEYPAD LOCK..BUT I WANT TO KNOW HOW TO MAKE KEYPAD SECURITY CODE SAME AS NOKIA..PLEASE HELP ME..
Dec 26, 2008 | Sony Ericsson S710a
Keypad lock with code
I am sorry but this function is not present with the Sony Ericsson K530.
Mar 20, 2008 | Cell Phones
Soyo SYXRT4791AB 47 in. LCD TV Logo
18 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
