Question about Texas Instruments TI-83 Plus Calculator
TI-83 countdown My daughter pressed 2nd key and up arrow on her TI-83 +, the dipsplay counted down from 5 and them went blank and has not come back. Cannot tell if the power is coming on or not. We have tried new batteries with no change.
Pressing 2nd then the up or down arrows is how you change the contrast on the TI-83. All you need to do is press the 2nd key then hold the down arrow to get your screen back. The countdown that you saw was just the value the calculator assigns to the contrast. It goes from 0-10.
Hope that helps!
Posted on Mar 08, 2009
Changed the batteries in my TI-83 plus calculator and now the screen has a black shadow.
Adjust the contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key to lighten the screen. If you go too far, press and release the 2ND key, then press and hold the up-arrow key.
Nov 24, 2013 | Texas Instruments TI-83 Plus Calculator
What's your problem?i have ti-83 plus and some parts of the screen is fuzzy expecially when I use the 2nd command. I have been using it in class andnothing out of the usual has happened to it. I just...
If you cannot see anything on the screen, you may need to adjust the graphing TI 84 calculator contrast :
1.To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light.
Apr 04, 2012 | Texas Instruments TI-83 Plus Calculator
My TI-83 PLUS wont turn on
Remove one battery from the calculator and then press and hold down the CLEAR key while re-installing the battery. While continuing to hold down the CLEAR key, press and hold down the ON key. If this doesn't work, then hold DEL and then ON. If unsuccessful, remove all the batteries, including the lithium watch battery, and leave the calculator like that for a while.
This is documented in the TI-83 Plus Guidebook, but unfortunately, not many people know about it.
If that doesn't work, send it to TI for repair. They probably won't even charge you!
Mar 20, 2017 | Texas Instruments TI-83 Plus Calculator
My son's TI-83 calculator screen is very dark. The calculator appears to be working but I can barely read the screen. Any suggestions?
Try adjusting the screen contrast. Turn the calculator on. Press and release the 2ND key, then press and hold the down-arrow key to darken the text. If you go too far, use the 2ND and up-arrow keys to lighten the text.
Feb 09, 2011 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus completely blank and won't turn on. All batteries are fine.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Oct 24, 2010 | Texas Instruments TI-83 Plus Calculator
My TI 83 plus has its screen pitch black and i cant type anything
Adjust the screen contrast. Turn the calculator on. Press and release the 2ND key, then press and hold the down-arrow key for a few seconds to lighten the screen. If you go too far, press and release the 2ND key then press and hold the up-arrow key.
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 21, 2010 | Texas Instruments TI-83 Plus Calculator
Screen is dark when turned on-already removed batteries and lithium battery-is ti-83
Adjust the screen contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key to lighten the screen. If you go too far, press and release 2ND then press and hold up-arrow.
Sep 15, 2010 | Texas Instruments TI-83 Plus Calculator
How to make screen on ti-83 darker
Turn the calculator on. Press and release the 2ND key. Press and hold the Up-arrow key until the screen attains the darkness you want. If you go too far, press and release the 2ND key, then press and hold the Down-arrow key to reverse the process.
Mar 16, 2010 | Texas Instruments TI-83 Plus Calculator
On TI-83 How do you change the batteries?
Try pressing the 2nd key and then holding down the up arrow key first.  This changes the contrast on the screen- makes it darker.  Pressing the 2nd key and then holding down the down arrow key will make the screen lighter
Feb 02, 2009 | Texas Instruments TI-83 Plus Calculator
Screen is all black
Try adjusting the brightness by pressing 2nd key or witchever name is on yours for the Alt key + the up or down arow key(as you see fitted)
Aug 25, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
161 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
