Question about Sunbeam Humidifiers
Sunbeam Cool Mist Tower Humidifier, SCM630WC-UM
Need to know how to replace the filter
SOURCE: Need help humidifier doesn't stay on
I've had this problem before and with mine, the issue is the water is not making its way into the correct reservoir on the bottom of the machine. With experimentation, I discovered that my tilting the machine slightly upwards on the righthand side corrects the problem (i.e. put something aprox. 3-5mm thick underneath the right side of the machine). You will hear that the water "move" to the left side of the machine and thus ensuring proper operations. I think this is a design flaw (for some machines) as clearly I have the same problem too.
Pc
Posted on Jan 09, 2008
  • 123 Answers
SOURCE: Replacement tank for Vicks Cool Mist V3500N
It doesn't look like they sell any replacement parts for this machine. I would call the manufacture and see if they will sell you one.
Good Luck.
Posted on Apr 18, 2008
SOURCE: Cool Mist Humidifier Filter Drying Out
Do you have tried to use without filter?
Posted on Jul 17, 2008
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
SOURCE: Sunbeam Ultrasonic Humidifier 696-12
tentative on the Solution icon ...
I picked this up a couple days ago at the Salvation Army, 3 bucks. I also had way too much damp coming out, saturating anything near.
I read through the comments, and one folk said they uncovered the spaz unit and tightened the screw they found there, to no avail. They asked if they should reopen and loosened the screw ...
Which I did. Took me a while, and maybe those who aren't used to investigating the inner workings shouldn't try it unless they're willing to make a mistake and throw it away, but ...
I loosened the screw. Not sure if it was a quarter turn or a half turn; I wanted to do more and have learned many times that "more" is not "better."
I have a cardboard box in front of the unit for hours now, and it is not saturated.
The factory setting, whether it be for all or some, is too wet. Loosening the screw that shows through the computer board has, for me, made the unit more tolerable. Takes an eyeglass-screwdriver to get it done, but if'n ya has the general know-how to investigate things, maybe it'll work for you.
Posted on Jan 07, 2009
When i plug in my sunbeam humidifier I get an er on the screen what should i do
Impossible to know without communicating with Sunbeam. "ER, ERR" and the like are normal failure mode displays whenever the unit can not operate as normal. As there are electronic components involved, a failure of any one will fault the unit.
And it could also be something as trivial as a buildup of scale on the water sensors. (Have you tried a thorough cleaning of the unit?) I would first try soaking the water chamber in white vinegar for several hours.
It that does not fix it, it's probably done for.
Jan 03, 2016 | Sunbeam SCM631-UM Cool Mist Tower...
Humidifier runs but no cool mist comes out.
1 amp fuse on circuit board blown... replace
Feb 12, 2011 | Sunbeam 701 Humidifier
I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
Dec 19, 2009 | Sunbeam Health at Home Warm Mist...
Vapor is not coming for sunbeam humidifier model 686
from all the information that i have come across. the unit is a cool mist. the vapor won't be apparent for the coolmist. now if it was a warm mist there is something internal that isn't making it cause any vapor. but if you done all the normal troubleshooting and nothing still and it has a filter it will more likely be a cool mist. warm mists don't have filters
Jun 27, 2009 | Humidifiers
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Mar 17, 2009 | Sunbeam 701 Humidifier
Humidifier
I have the evenflo cool mist humidifier, model # 758100. There should be a model number on the unit. As far as replacement filters, you can buy the Holmes humidifier filter, model # HWF62. It's compatible with Evenflo. I bought a 2-pk at Target for $15.99. Hope this helps.
Jan 09, 2008 | Evenflo Evaporative Cool Mist Humidifier
Humidifiers Logo
272 people viewed this question
Top Sunbeam Humidifiers Experts
Paul Sikkema
Paul Sikkema
 steve
steve
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
