Question about Panasonic Lumix DMC-FT20 Digital Camera - International Warranty
Is it possible to get a Lumix - FT20 camera repaired after water damage?
Bought this camera for travelling around Asia with in September. I'm prone to breaking other cameras so it needed to be sturdy, waterproof, drop proof etc. However somehow it got water damage, the lock is ALWAYS on as I'm paranoid that it isn't really waterproof. Started to trust it after two months of life with me, it had been in the sea, pools, up mountains, motorbikes etc, it seemed man enough to survive life with me, I don't understand how when I always follow the guidelines that it got water inside, it had been in water plenty of times already. The only thing that showed this is that the small strip had turned pink, no obvious water. It wont turn on at all and it's not just the battery as I've tried new ones. Can it be repaired at all or do I just give up and assume there's no standard camera in the world that is robust enough?
dbarchitect
  • 150 Answers
SOURCE: lumix pictures blurry
I would suggest that the image stabilizer might not be working right. Could you upload a photo to Flickr or other location where I could look at the EXIF, or list it here. I would like to see what the camera is writing to the image as the settings when the photo was taken.
Does it make a difference when the image stabilizer is on or off?
Posted on Nov 23, 2007
SOURCE: Lumix TZ3 keeps giving the same error message: "Please turn camera off and then on again"
sorry to tell you guys this but you definetly have lens faults, for you firwol i can say that you have a focus lens or image stabilizer fault, bob80 sand can definetly mess your lens around and is going to need a service. you can check the error codes. you need to do exactly what i say. turn camera off, mode switch to red camera selection, this has to be done quick, turn camera on holding the ois+ arrow up button, then quickly hold ois+menu+arrow left. post the error then i will tell you what is wrong.
Posted on Jun 26, 2008
SOURCE: Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
Posted on Jul 09, 2008
  • 96 Answers
SOURCE: LUMIX DMC-LS80 SHOWING MESSAGE PLEASE TURN OFF CAMERA AND TURN ON
This fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. It will need to be serviced by an experienced technician.
Posted on Sep 30, 2009
  • 11967 Answers
SOURCE: Panasonic Lumix DMC-FX8 digital camera - marks on each photo
I was thinking along the lines of some kind of fungus if you were in a warm, humid climate.
Posted on May 05, 2010
Testimonial: "Thanks for the advice. Any idea how to get rid of it?"
Insert sd card again
At this time we recommend you use a different SD card and format it. SD cards can become corrupted and the camera may not recognize your card any longer.
Apr 13, 2014 | Panasonic Sale Lumix Dmc-ts20 Waterproof...
How to slove system error(zoom) of my panasonic lumix dmc-fs15
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 01, 2012 | Panasonic Lumix DMC-FS15 Digital Camera
Digital camera can't turn on
It's impossible to say what needs to be repaired without knowing what's damaged.
The battery compartment probably is the worst place to have water. Everything in the camera runs on electricity, and all the electrical power comes from the battery.
If you immediately removed the battery and let everything dry out thoroughly, then you might get lucky and not have anything to repair. If you tried to turn it on while wet, you very well could have caused additional (possibly fatal) damage.
May 02, 2012 | Canon Cameras
Everything is working except the LED screen which is blank. Possible water damage from rain. Any solutions?
First thing to do whenever you suspect water damage is to take the batteries out, open as many doors and caps as possible, and let the device dry out for 2-3 times as long as you suspect it should take. Sometimes in humid environments you can put the device in a container and dump in some clean dry rice. Cover it and let the dry rice pull some of the moisture out. Don't let rice get in the camera :) As a last resort, you can disassemble the camera as far as you feel comfortable, then dump some denatured alcohol in and around the screen to help flush out the water and possibly clean any residue left on contacts by the drying water. After this, again let the camera dry out completely before even reassembling. If it still doesn't work, it may be time to get a new camera. Good luck!
Aug 16, 2011 | Cameras
Panasonic camera lens problem Can't get to focus or the lens doesn't go in when knock It off only when u knock it off
If the lens won't go in there is something physically damaged in it. Your best bet is to take it back to where you bought it if it is still under warranty. Or you can take of to a camera or electronics store that does service work and see if it is worth getting repaired or cheaper to replace it.
Jul 30, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
First off, my wife is traveling and let me know of this problem, so it will not be an accurate description. When she turns it on/off, the lens does not close, it stays extended. If she tries to take a...
The lens is damaged and needs to be replaced, the rest of the camera should be fine. You can get a refurbished one installed for under $100, and Panasonic will do the repair with a new one for probably around $150. Wish I had better news, sorry.
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
May lumix dmc fz8 dropped into salt water and won't turn on?
Do not insert cell or battery in your camera & do not try to switch ON the camera. otherwise it will harm your device.Send your device for repair, there is no other way to fix the problem.
Good Luck..
Feb 28, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Canon camera sc980- screen won't work, cannot format card. So effectively camera in NOT working- less than 3 months old now. Just returned from a 6 week trip to Asia & the camera, bought new about 3...
Well, I'm not sure what you expected them to do...send someone to Asia to fix your camera? They responded the only way they could. They didn't ruin your trip...you could have bought a cheap throwaway digital camera and enjoyed the trip. Now you need to send it in for repairs under the warranty.
Feb 27, 2010 | Canon PowerShot SD980 IS / Digital IXUS...
Colors are bleached out
Beaching symptom is most likely damage due to CCD chip problem. Unless the Panasonic has CCD advisory repair at no charge, cost of replacing CCD chip would be beyond economical repair. Cost of repair was going around $100 at www.camerarepairjapan.com , James.
Mar 26, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-FT20 Digital Camera - International Warranty Logo
83 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
