Question about LG LRTP1231W Top Freezer Refrigerator
Vegetables freezing in lower trays
Anything kept in lower trays are freezing rock solid. How do we solve this problem?
  • 2,427 Answers
Lower the temperature in the temperate control and then lower the humidity control vent to half open on the trays themselves.
the main reason is your temperate is to cold.
Posted on Dec 30, 2012
Hi, I have a home work question, what does lithosphere? thanks :)
That is is the solid outer section of Earth, including the crust or rock layer on the outer layer of the planet, the oceans, and the upper solid part of the mantle. Next down is the lower mantle and the core.
https://en.wikipedia.org/wiki/Lithosphere
Apr 15, 2016 | Optics
Water Shute freezing up in ice maker
freezer maybe turnedup to high ck manufacturing recommendations
Feb 06, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Can not go down deep enough below the freeze line without hitting solid rock. Is there anything out there to insulate the line without costing me a fortune...
when you say "insulate the line" I assume you mean water line. the only thing that you can do is to use "heat tape" and then over that you would place fiberglass insultation and silver tape to keep the insulation on the tubing. If you live in a climate that isn't too cold and has a short season, the built in thermostat on the heat tape will prevent it from "costing you a fortune" mobile home tubing is often insulated this way and its not very expensive to maintain an above freezing temp.
Mar 22, 2011 | Garden
Can the struts or shocks freeze on my 2005 equinox? It started a couple of weeks ago when the temp went below freezing.
Yes if they are leaking and you go to a car wash and then the temperature goes below freezing. It happened to me. Car started rocking all over the place because water got inside the strut and then froze solid overnight
Jan 10, 2010 | 2005 Chevrolet Equinox
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Samsung refrigerator model RS2577SW. Can't lower
Try turning off the unit. Then leave both doors open for 48hrs to defrost it 100%. Now try moving the icemaker bar as there may be ice in side freezing it solid. If not I'd say it's time for a new ice maker Cheers
Mar 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
THAT I HAVE A RIVAL 8804 iCE CREAM MAKER AND IN THE WEB SAID THAT I NEED ROCK SAL AND I NO HAVE BUT I HAVE THE MILK,ICE,VANILLA BUT I NO HAVE THE ROCK SAL AND I HAVE A QUESTION THAT IF I NO HAVE THE ROCK...
Rock salt is also used to make ice cream. It is not actually used in the ice cream mixture; rather, it is used to melt the ice surrounding the can holding the ice cream, causing the ice to melt at a lower temperature, thus lowering the temperature of the ice bath and quickening the freezing process.
Dec 30, 2008 | Heating & Cooling
Timing is off
timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Jul 08, 2008 | GE WSXH208A Front Load Washer
Freezer is over-freezing
the possible cause is the temperature sensor or thermostat is not working, maybe its switch is stuck up on ON position, it looks like a wire attached to the area where ice is building up, it is connected to a switch to turn off the compressor thus controlling the operation of your freezer. replace with new thermostat will solve the prob.
Aug 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
LG LRTP1231W Top Freezer Refrigerator Logo
88 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
