NEO3410 HD SET TOP BOX WITH TWIN TUNER
WHICH IS THE RECORDER YOU HAVE TO CHOOSE, IT JUST SAYS RECORDER? WHAT HAPPENS NEXT IS THAT IT COMES UP WITH NOT VALID ENTER RECORDER:(
2 Suggested Answers
  • 27 Answers
SOURCE: At Step 4 of the installation, each time I hit
it is becuase the dazzle capture device is not selected as your video source. Please try to go back to step number 1 select video source . Make sure that pinnacle file capture is not selected but the dazzle is selected then try it again.
Posted on Mar 04, 2009
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
ยท Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
Www philips com support
This unit doesn't have a tuner of any sort. Even on the few DVR/DVD recorders that have tuners, the external composite video inputs do not connect to the tuner. To record from the L1 or L2 inputs, you must be using a set-top box (cable, satellite, or digital-to-analog converter for OTA signals) or another video source (video camera or a vcr). Most TVs do not have video output capabilities. If you have one of those, follow the directions for recording from set-top boxes below.
Turn on and set the source to the channel that you wish to record for any set-top box. Then make sure that the set-top box is left on and at the correct channel after you finish setting the frequency, speed and length of time for the recording. Note: if the set-top box is turned off, your recorder will still record the blank video and audio.
What source do you have connected to the VCR?
To record from a video camera or a VCR, set that source to play back at the desired time point. This is best done without the timer. Just start recording and then the playback.
I hope this helps. Please add a comment with your video source for more support.
(My OTA tuner has a energy-saver option that turns off the unit when there is no activity for a while. Since I usually record when I'm either asleep or away from home, I had to disable the feature to get the correct recordings.)
Jul 04, 2013 | Philips DVP3345VB/F7 DVD Player/VCR
How to reset the pin for Panasonic DMR-HW120EBK 500GB HDD Recorder with Twin Freeview +HD Tuners (2012)
This is the definitive answer from Panasonic Customer Services. It worked for me.
In response to your enquiry, I am writing to inform you that you can reset the PIN number to the default 0000 and then change it, based on your preference. In order to reset the PIN, please follow the next steps:
1. Switch ON the unit;
2. Press and hold the OK, YELLOW and BLUE buttons, at the same time, until you see 00 RET displayed on the unit;
3. Press, repeatedly, the RIGHT ARROW buton until you see 03 VL;
4. Press OK and you should see "INIT" displayed on the unit.
This will reset the PIN number to the 0000 factory preset.
Furthermore, you should also be able to remove the message that is asking you for the child lock PIN while attempting to play back a recording. In order to do this, please follow the next steps:
1. Press SETUP;
2. Choose HDD/USB HDD;
3. Select CHILD LOCK FOR PLAYBACK;
4. Input the default 0000 code;
5. Switch it to OFF.
After performing these steps, the recorder should no longer ask you for the PIN when trying to playback a recording.
I trust that the above information will be of assistance to you. However, of course, if you should have any further queries, please do not hesitate to contact us.
Kind Regards,
George
Customer Service Team
Panasonic UK
Feb 19, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
Lite on - hd-a740gx
The LG HD-A740GX does not have a digital tuner. The analog tuner included depended on the country of sale; it has a PAL (UK) or NTSC (US) tuner. You'll need a set-top box (digital-to-analog tuner or cable or satellite box) to provide the signal for the unit to record anything.
I wish that I had better news for you.
May 07, 2012 | Televison & Video
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
My problem is I have a dvd player DMR-ES 15 I live in australia is it possible to tune in the new tv stations example seven 2
It is not possible to tune in 7two, channel 11, GO! or similar digital channels with this model DVD recorder, as its tuner would most likely be analogue only. You would either need to upgrade to a model with a digital tuner built in, or purchase an external set top box, capable of SD and HD digital reception, and connect its AV outputs to the respective inputs of the recorder, in order to record the channels you want.
However, being in OZ, those digital channels are available as free to air - all you would need is the appropriate receiver to enjoy them. I recommend a set top box which offers HD as well as SD.
May 05, 2011 | Panasonic DMRES15 DVD Recorder
Now that we are on digital will the SD-37VB dvd vcr recorder work or do I have to alter a setting to make this happen
If the unit has a built in analogue tuner, the unit itself will still operate as normal, but without the built in analogue channels - to record a TV show, you would need to connect an external set top box to it (SD or HD - or both).
In other words, apart from a separate set top box, if required, there should be no need to change any of the unit's settings if it works as is. I do not believe this model has a built-in digital (DVB) tuner.
Apr 13, 2011 | Toshiba SD37VB DVD Player / VCR Combo
I recently purchased an LG RH397D dvd recorder> Ihave now discovered taht it will not receive the new free view channels and I need a HD set top box. How to I connect the set top box to the dvd...
Hi, The set top box will more than likely have two coaxial connectors ( threaded/ribbed pieces of metal ) coming out of the back. also three R.C.A. connectors-these will be smooth and be colored yellow red and white. one of the coax connectors will say " IN FROM ANT> or CABLE IN) the other ( OUT TO T.V. ) hook up your dvd recorders " ANTENNA " input to the set top box's ANTENNA output. If your D.V.D. recorder doesn't have an antenna input then hook up the recorders audio/video input to the set top box's audio/video output. then you should be good to go. If you buy a H.D.T.V. tuner to receive FREE H.D. programming it may be possible to hook up to recorder with H.D.M.I. cables.( those connections resemble slots ) I hope this has been of some assistance, good luck, Prodzilla.
Apr 02, 2011 | LG Televison & Video
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
I cannot get the new digital channels throught my Panasonic DMR-EX87, that have become available of late, (GEM, 7MATE and ABC News24, I am in Australia). I have performed a system update and...
The tuner in this DVD recorder is a DVB-T SD tuner; it will also tune in the analog signals if you have any analog stations in the area. You will need a separate HD tuner (set-top box) to provide the HD content. I'm not sure if you can record from a set-top box with the recorder set to Line In or Input. The only input jacks are the A/V (composite) jacks.
I wish that I had better news.
Dec 03, 2010 | Televison & Video
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
