Question about Cell Phones
Touch screen not sensitive at all
I was pulling my phone from my tight pocket the other day, and the phone's screen function ran out of order, and different touch areas started doing functions they shouldnt, i reset the phone to factory settings, i had a hard time touching the calibrating small red dot, but after atleast 200 times it said calibration complete, but on powering back on, the phone screen lost all sensitivity, and now cannot even unlock it... please help
  • steve n Dec 30, 2012
    thanks Rishi, i can only hope it wont cost as much as just getting a new one.
  • 2,427 Answers
The screen itself needs to be replaced or the digitizer for it.. in either case it needs to be repaired by a professional as it will need to be checked first by switching the parts to determine which one is at fault before replacing it. unless you plan on buying both it will be cheaper to have it repaired in a local shop.
Posted on Dec 30, 2012
SOURCE: p990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Posted on Sep 17, 2008
SOURCE: The touch screen and the pen do not pair to function
my i9 phone does not apply the touch screen anymore and the pen calibration i cant click on screen . when i try to calibrate it keeps on the same infomation of "touch where the point is , left, center and right.
Posted on Dec 24, 2008
SOURCE: My SGH-U700 touch sensitive keys
Usually the pins on the FLEX shorts out when liquid gets between the connectors and dries. Or the connectors are just loose, this is because you don't take good care of your phone.
Well you have to let someone replace/reconnect/check the FLEX of the phone, Replace cost's around $20-$40 (or around 200-500Php)
Posted on Dec 26, 2009
  • 4 Answers
SOURCE: want to factory reset an unlocked htc touch cdma (vogue)
All you have to do is... hold down the (RED) End button and the (GREEN) Send button at the same time, and while still holding them down POKE your stylus in the soft reset hole at the bottom of phone.
Soft Reset button is located to the right of the mini USB charging port, assuming the phone's screen is facing you.
Confirm you want to Format and Done!
P.S. Sometimes if you don't hold the Green and Red buttons hard enough they tend to unclick and reclick if you don't apply Firm and even pressure. Also if you still have trouble make sure the phone is in the BOOTING cycle when you attempt this.
Posted on Feb 03, 2010
SOURCE: china mobile
hey guys if yr mobile show this ERROR
"Calibration wizard. You have to calibrate the touch-screen. Click anywhwere on the screen with your stylus to start calibration".
just send sms on that mobile where u getting this error and PRESS Red button or CALL END button..than u will show New and Cacel Option Then Select new..yr mobile will come on Ready to use..
Posted on Nov 21, 2010
Touch screen lost sensitivity
you need to order the lcd and touch screen to fit your problem.
has a look here.
Jun 26, 2013 | Apple iPhone4 4G iPhone 4
My touch screen on my ex 119 is only pressing and i'm not getting the touch at the bottom of the screen
I would send it back to the manufacturer, it sounds as though you may have a defective phone or cell phone.
Oct 06, 2012 | Motorola Mobility Ex119 Ex-119 Dual-sim...
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
Just got this phone used. Touch screen does not respond. Everything else seems to function
Touch screen phone are too sensitive, common causes are when dropped on the ground,water damage and pressed by inserting it on fitted jeans or pants pocket. once even one portion is not working,they are not repairable, indeed need a replacement.you can ask assistance to any mobile service shop near you.
Jun 27, 2011 | Samsung SGH-A877 Impression Cell Phone
My touch screen not working SAMSUNG A867 ETERNITY
If you have any functionality at all left to your touch screen, try to recalibrate it within the settings menu. Otherwise, remove the battery, wait about 15 seconds, then reinstall.
If that doesn't help, the touch-sensitive surface glass has gone out. Apparently, this component in the first-generation Eternity has chronic failures.
Replacing it is not too much trouble for an experienced cell phone technician. But, it's not for anyone who doesn't like to tinker with small things. Here's a video demonstrating the entire process: http://www.youtube.com/watch?v=QJpHHs9QM5U.
Jan 23, 2011 | Samsung Eternity Cell Phone
Touch screen out of order
you should reset your mobile phone.if any touch screen is not functioning you can reset your phone.A pin hole is given near the usb port of phone for reset it.you can enter a needle into pinhole & press it slowly.after that your phone will reset.it take some moment. after it screen appers with text "align screen".taping the target until the "align screen" disappears.after disappearing align screen set which is given on the screen.after that windows will be installing.it take some moment.i hope your problem will be solved.
Dec 02, 2010 | i-mate JAM Pocket PC
Touch Screen is not working
Since this is the case you may need to soft reset the phone.
The touch screens normally give problems whenever there is a little pressure applied to its surface e.g when you don't use a pouch but place the phone in a tight jeans pocket and thus will need,screen reallignment.As you may already know.
Now your phone has a soft reset function...try it! Or turn it off,remove the battery (not immediately! so you don't loose your settings then re-insert it after 25 secs.) and do a restart. This should allow you access the screen allignment settings so that you could fix your screen.
Hope this helps.
Sep 23, 2009 | HTC XV6900 Cell Phone
My I-mate touch Sacreen is not working
Reset your phone! and if you dont mind loosing your information run a complete reset.Then do a screen re-allignment.
To avoid a future re occurence avoid placing your phone in your tight jeans pocket so that you don't apply pressure to the screen.
Aug 02, 2009 | i-mate JAM Pocket PC
My Htc Touch pro screen, looks like it has a large wet spot in the middle, i know for a fact it hasn't been near water, my screen is totally visable but not able to use by touching the screen, what could...
I suggest taking it to your compaany store but before you go to the store and have them tell u the phone is water damaged, you can save yourself the trip by looking for yourself. There should be a little square located in the back of you phone right below the battery and a little square locatedd on the batery where it connects to the phone. If the phone has water damage then the littl e squares should be red if they dont have water damage, the squares should be white with a plaid kind of design.
Jun 17, 2009 | HTC Touch Pro Smartphone
External screen blank on razr v3
razr phones are sensitive phones, check service center near your area or check manufacturer for repair.
Sep 26, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Cell Phones Logo
94 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
