Question about Acer Aspire One D250 16GHz Intel Atom Netbook w Webc LUS680B516
Acer aspire one d250-1bw won't boot up.
When memory insert it turn off
luis356
  • 53 Answers
SOURCE: acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Posted on Jun 02, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
leecom72
  • 4806 Answers
SOURCE: acer aspire one
Its possible the computer is trying to boot from another device, as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
If not hit F2 as it starts and enter the BIOS, look for the boot option and set the HDD as the first boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system
Please post back if you need anymore assistance.
Regards.
Posted on Aug 06, 2009
  • 8 Answers
SOURCE: Aspire One PC Notebook: My acer one aspire turns on but screen stays black...
Try this for the black screen of death problem...
Here’s what you need:
  1. USB Memory stick (as low as 128mb)
  2. Another PC with a net connection
  3. WinZip, WinRAR, or some other program that can extract zip files.
  4. A quick visit towww.acer.com
  5. Your Acer Aspire One, that will power up/turn on, but the screen does not come on.
And here’s what you do:
  1. Go to www.acer.com and go through the DRIVER support pages until you get the Aspire One driver page for your relevant Aspire One model (110/150/751)
  2. Click on the tab on the download area that reads ‘BIOS’ even if it looks like you can’t click on it (their site design grays it out but it’s there) and download the BIOS file numbered 3310 (it might have changed version recently but do it) and don’t worry, you can trust this file, as it’s from Acer directly.
  3. Extract the zip once downloaded and find in the DOS folder the files ‘flashit.exe’ and 3310.fd
  4. When you’s ve found them, rename 3310.fd to ZG5IA32.fd and put this renamed file and ‘flashit.exe’ onto the USB memory stick
  5. Put the USB in the Aspire One and hold the keys ‘FN’ (function) and ‘Esc’ (escape) and keep them held when you turn the laptop on
  6. Watch the power button and when it starts flashing, press it once (DO NOT DO ANYTHING ELSE)
  7. You should notice the USB (if it has a light) blinking as well… The netbook has started ‘flashing’ the BIOS and after about 7 minutes, the netbook should shutdown and reboot itself and VOILA! The screen should turn on just fine.
It took my three times but this IS the proper solution! I am now very happy with my Aspire One that still works!
Posted on May 21, 2010
sayedmohu
  • 633 Answers
SOURCE: Hello.My ACER Aspire One netbook
I would suggest u to do a power drain before contacting a tech.
For that remove the battery and unplug the charger.
Hold down the power button for 20sec.
Put the battery back in and power on the computer.
Posted on May 23, 2011
My acer aspire 7735z turns on but won't boot up
your hard disk maybe corrupt.
The operating system is in the hard drive, so if it won't boot, your OS might need to be repaired or reinstalled.
You will be needing OS CD to carry out the re installation
Good luck.
Nov 28, 2012 | Acer Aspire 7735z 17.3" Laptop Original...
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Acer aspire 6920 won't boot up
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 30, 2012 | Acer Aspire 6920-6422 Notebook
Help!! I have an Acer Aspire Laptop. It wont boot up!!
Hello, "Suzy Irwin".
You wrote that this is the error message:
"Check cable connection! PXE-MOF : Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key".
Is that correct?
IF so, 1st, Good Job!
Most people miss the mess., then we don't have the info we need.
OK, "PXE ROM" indicates that the POST can't find the hard drive.
"No bootable device" usually indicates the connection to the hard drive, or the drive itself, has failed.
When it says; "Check cable connection",
that's another indication of the same problem.
So, do you feel comfortable taking your "Acer Aspire" apart?
IF its in warranty, or if you don't think you can take it apart,
AND put it back together again,
then you will need to take it to a shop or store that does repairs,
or buy another computer.
But IF you feel up to it, check the company's website,
and google the instructions for disassembly/reassembly for your particular model.
Your description of the problem didn't include the model info, or any additional info to further ID your particular Aspire.
They are NOT all alike.
Hopefully helpful,
sl0j0n.
Jul 27, 2012 | Acer Aspire One PC Notebook
Why won't my laptop boot?
sounds like an unhappy computer try this
turn off computer
press F8 and turn power on at same time
should open to SAFE Mode
run that for a bit then restart
let me know how that works for you
May 22, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
I have Acer 1200 Aspire. When I turn it on, it won't proceed past the initial window. It says boot failure.
It almost sounds like your primary boot disk is incorrectly selected in the BIOS. On older machines, the primary disk on the primary cable had to be the boot disk, but nowadays almost any device can be selected as boot disk. Check your BIOS setting and ensure that the hard disk partition that you have Windows installed on is selected as the first boot device. Otherwise, the system may be looking in the wrong place for the OS and giving the boot error.
Jan 07, 2012 | Acer Aspire X1200-B1601A PC Desktop
I tried to upgrade the memory from 1 GB to 2 GB, but after that the computer's screen won't turn on, and i can hear three long beeps and two short ones
The beeps indicate memory issue.
Acer Aspire One Notebook supports upto 1.5GB of memory, so if you try to install 2GB it will not work.
Size 1.0 GB / 1.5 GB (max)
Technology DDR2 SDRAM - 533.0 MHz
Form Factor SO DIMM 200-pin
You can also Click Here to check the specs on the Cnet website.
Regards,
Shrey
May 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One D250 16GHz Intel Atom Netbook w Webc  LUS680B516 Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
