Question about Garden
20hp robin engine starts hard
Starts hard when cold
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Step 1:
Check your spark plugs to make sure they are not worn or dirty.
Step 2:
If the spark plugs are not worn and your engine cranks normally then check to make sure that the choke is working properly. The choke may be set too rich or too lean. Either way can cause hard starting. Inside the choke housing is a bimetal spring that regulates the tension on the choke according to temperature. If this spring is broken, the choke will not operate. If the choke linkage is rusty or jammed with varnish deposits or dirt, it may stick or not operate smoothly. Cleaning with carburetor spray or solvent may help alleviate a sticking problem.
Step 3:
On older fuel injected engines, a separate "cold start" injector is used to spray additional fuel into the intake manifold when a cold engine is first started. If this injector is not working, the engine can be hard to start. The injector is controlled by a timer and relay, so if either of these components is defective it can prevent the cold start injector from doing its job, too.
Step 4:
If your engine cranks slowly, your cold starting problem is not fuel related, but may be due to a weak battery, loose or corroded battery cables, or a weak starter.
Step 5:
Check for obvious problems first. Remove, clean and inspect the battery cables (both ends). Then check battery charge and condition. (More information on the condition on your battery and battery recharging is available.) If the battery charge is low, recharging the battery may temporarily solve your problem. But there's a reason why your battery is low. You probably have a charging system problem that requires further diagnosis. (More information on alternators is also available.) If your battery is more than four or five years old, it is probably near the end of its service life and needs to be replaced. A "load test" will tell you if it still has sufficient cranking capacity to provide reliable cold starting.
Step 6:
Slow cranking during cold weather (below freezing) can also be caused by oil that is too thick. A high viscosity oil such as straight 30 or 40 weight oil in the crankcase can make an engine very difficult to crank when the temperature drops. Switching to a lighter multiviscosity oil should solve this problem.
Step 7:
If none of these work the just take it to a repair shop and let them deal with it because you put in enough work doing this.
Posted on Dec 31, 2012
What are the valve clearence settings for intake and exhaust on 20hp b/s #461707
.004"-.006" on intake and exhaust valves cold engine. I would set them at .005" .
Feb 16, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Honda 20hp wiring diagram
are you trying to install a key switch assembly i can help you just indicate color of wires your dealing with,honda tech 30 years
Aug 25, 2014 | Honda Engine 20hp Horizontal Tapered Shaft...
Kohler 20hp cup cadet
its trying to vapor lock try replaceing gas cap and see if its better
Jul 26, 2014 | Garden
Homelite LR5550 serges when it runs is there a way to set the governor so will run smooth
Try opening the high speed jet about 1/8 turn. If that don't work clean the carb.
Jul 07, 2014 | Garden
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Tappet clearance and spark plug gap on 5.5 hp ohv engine, i have a generator which runs on natural gas made by china i just want to know the gap of tappet and the spark plug gap
I have a Robin but they all are pretty much the same for plug gap and tappets. I worked in a lawnmower small engine repair shop for many years in San Diego
I set them all the same and never had one return. I just did mine a couple of months ago and hand lapped the intake and exhaust valve seats. Starts first time everytime like the 7.5 year old unit is new!!!
Plug gap 0.19
Tappets
Intake .005 cold
Exhaust .006 cold.
Jan 25, 2010 | Watts Onan Portable Generator - 4000 ,...
Looking for Intake + Exhaust valve clearances for Craftsman 20hp lawn tractor model# 917.276813 Engine # 31P977
The cold setting is .002 for the intake and .004 for the exhaust.I just set them both at .003 and it works fine.
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Where can I get an subaru engine manual for 10 hp
Here your are. Subaru engines are made by Robin. I don't know if Robin owns Subaru or Subaru owns Robin. Any time you need a manual you can get it from the Robin America site.
http://www.robinamerica.com/media/manuals/128547541213915000.pdf
Feb 27, 2009 | Coleman Powermate Premium Plus 6250W...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
