Question about Car Audio & Video
I got PPI amp. P900.4 And the protection red light is on. How can I reset this amp?
2 Suggested Answers
XSdB
  • 80 Answers
SOURCE: ppi amp
Here is an archive od PPI PowerClass manuals...
http://narbi.free.fr/manuels/Amplis/Precision%20Power/Serie%20Powerclass/
Posted on Jun 12, 2009
I HAVE A PPI PCX 2200 THAT IS NOT GETTING ANY POWER AT ALL I CHECKED ALL FUSES STILL NO POWER
1.verify connections...Make sure your ground wire is grounded to a location on the body where you will sand the paint away to make good metal to metal contact. 2.with a volt meter check for battery voltage on the red wire of the amp as close to the amp as possible.verify that your remote or trigger wire from the radio (blue wire) id connected to the remote terminal of the amp.. turn on key switch, turn on radio and see if amp powers up. if no then verify 12 vdc at the remote terminal of amp, very 12vdc at red power wire. verify ground. If all this is good i would suspect you have a faulty amp.
May 05, 2011 | PPI PCX-480 Car Audio Amplifier
I just got my PPI dcx 300.2 amp back and i hooked it all up, and connected the fuse back in and started the truck, the amp turns on but the red light starts blinking and says clip out. The amp doesnt smell...
Are you sure everything is correctly connected. If you are running the amplifier in bridge mode then take note that the load to the amplifier can be no lower than 4OHM. dreamsystems
Feb 25, 2011 | PPI DCX-300.2 Car Audio Amplifier
My PPI4240 has gone in to protect mode (red light is on). How do I get it out of protest mode?
protect comes on bfor several reasons:
1. short circuit/crossed speaker wires- examine the speaker cables very carefully, paying particular attention to loose strands at the ends that may be crossing.
2. blown speaker/fried vioce coil- push in on the speaker and it should push down about an inch with no resistance befopre bottoming out. if there is resistance, and/or it feels scratchy/rubbing when pushing in then the speaker is blown.
3. blown amp.
Nov 25, 2010 | PPI4240 Car Audio Amplifier
Why is my ppi2240 amp have a red light on? whats it mean when its in protection? why isnt it playing?
It means something is wrong...could be any number of things. Check your ground wire, make sure it is clean and tight. It could be turned up to high for your sub to handle,you could have a blown voice coil on your sub...need more info on what you're running and how long you've had it
Apr 15, 2010 | PPI2240 Car Audio Amplifier
RODEK AMP PROTECTION
have you checked your speaker connections and any other connection for shorts or multiple ground loops. cause that will definately cause the protection mode.
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Protect light flashing on and off, sub cuts in and out
there is a wire crossed somewhere in the system or the sub is damaged how old is the amp
Dec 01, 2008 | PPI DCX-600.4 Car Audio Amplifier
Ppi amp
Jan 30, 2008 | PPI PC2600 Car Audio Amplifier
AMP
If the amp gets hot or goes into protection with no input signal and no speakers/wires connected to the speaker terminals, the amp likely has shorted output transistors. It's not a complex amp. Any reputable shop should be able to repair it.
Sep 16, 2007 | PPI DCX-600.4 Car Audio Amplifier
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
