Question about Sharp LC-39LE440M Multi-System LED TV
IS SHARP LC-39LE440M A LED TV? - Sharp LC-39LE440M Multi-System LED TV
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
satavlad
  • 405 Answers
SOURCE: sharp flat panel tv,need manual for lc-19sb25u
http://www.sharp.ca/manuals/default2.asp
Posted on Oct 24, 2009
SOURCE: I need a diagram for lcd tv Sharp LC-26SB14U.
I have a sharp LCD (LC-26SB14U) which I purchased one year ago and today the sound stop working as I was watching the olympics. Any idea how to fix this problem as the warranty is only good for a year.
Thanks, Bob
Posted on Feb 27, 2010
How do I download latest firmware onto my Sharp Aquos LC-52LE640U?
hi does your tv have usb port if so, go to the sharp website look enter the model number of your tv look for firmware for your tv download it, then load it on to a usb flash drive, thanks
shaun
Mar 16, 2017 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
Lc 39le440m no picture, Backlight ok.How to repair?
The tcon bard or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Sep 12, 2016 | Sharp LC-39LE440M Multi-System LED TV
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
Is it reliable link and support shrap? Thank you....
Hi, I've used this company/website for over 12 months now with no issues whatsoever:
Sharp LC 29LE440M
However I would expect that Sharp would offer this firmware upgrade direct if you are still unsure
Dec 18, 2015 | Sharp LC-29LE440M Multi-System LED TV
Hi I have problem with my sharp LC-39LE440M Lcd tv when i turn on tv for 5 second it works normal after large clored line appear..menu didnt work and color and picture goes...please help
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 04, 2015 | Sharp Televison & Video
My sharp aquos tv LC-60LE632U has picture but no sound, What can be done?
Check the audio 'output select' under the Systems Settings menus. The output may be set to 'variable'. Set it to 'fixed' so that the audio runs through the speakers.
Oct 12, 2014 | Sharp AQUOS LC-60LE632U 60" LED TV...
I have a sharp aquos lc-39le440m but it wont play movies using usb
lc-39le440m does have a usb media player ,if you able to view file in the drive ,but unable to play it file format might wrong , else the port/board is damaged
Apr 08, 2013 | Audio Players & Recorders
Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
May 11, 2009 | Sharp LC-13AV1U Television
Sharp LC-39LE440M Multi-System LED TV Logo
228 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
