Question about Refrigerators
Model ice102c stopped making ice
Was tipped over to empty water and has not made ice since.
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
  • 92 Answers
SOURCE: 10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Posted on Oct 31, 2007
  • 12 Answers
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Posted on Mar 10, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Model GS6NBEXRL01 ice maker not making ice
Most likely the water control valve on back of the refrigerator near floor or the thermostat inside the ice maker is defective. You can fill the ice maker with water from tap and see if it cycles one time or you can check the control valve solenoid that feeds water to the ice maker. Click on link below and then paste your model number in model search feature. That takes you to a page with breakdown photos of the parts I mentioned. On the left of your screen click on photo # 12. If you need help with this I am here, just let me know, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
My ice102c ice maker quit pumping water
Notwithstanding the excellent parts companies below it appears that only
HOMEDEPOT.COM will support this device...
Model: ICE102-WHITE
>>> Questions:1-800-968-9853
Appliancepartpros
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
partsselect.com
easyapplianceparts.com
Find Your Appliance Parts
Jan 14, 2016 | Refrigerators
Ice maker not working on a whirlpool french door fridge
Is the cold water dispenser working? If not, does the filter need to be changed? Do you actually have water supply to the fridge?
Is the Ice bin empty? Is this your fridge, or are you renting and this was in place? If yours, do you have an Owner's manual with the troubleshooting tips? No manual, try manualslib.com Make model possibly year and serial number. If not yours, there should be a switch that turns the Icemaker on or off. A green light on the front of the drive mechanism near this switch should mean it does have power. No light, no power. There should be a mechanical switch that stops the Ice maker. If the bin is empty, the ice detection arm should be down If it is not down, It is stuck in the "bin is full" position. If these are not the problem, It may be the electrical valve for the Icemaker water supply is not operating, or has been disconnected, or is bad. I have found that one of the online "appliance parts store or sites" have been quite helpful in diagnosing problems and recommending parts and how to fix.
Apr 01, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
How to clean igloo portable ice maker
Maybe scaling has occured, get descaling chemical to clean it. Also remember to remove the dust accumulate at the condenser..
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Kitchenaid superba ice maker not making ice
Put some water in the tray. Let it freeze and once frozen will the ice then empty into the ice bin? If yes then the problem is possibly one side of the water control valve is defective. This is not the correct water control valve for your model number. HERE You need to provide the correct model number first.
What is the model number? I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | KitchenAid Refrigerators
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
My ice maker doesn't work. Where do I start? Model number 561
HI.FIRST MAKE SURE U HAVE TURNED IT ON.SWITCH OR LEAVER.2- WATER ON 3-WATER IN ICE TRAY.4 IF EMPTY PUT SOME ON MANUALY.AND TRY.IF IT WORKS ONCE AND STOPS THEN U HAVE A WATER SUPPLY PROBLEM.CHECK PIPE;WATER VALVE.IF ALL OK THENNNN...ICE MACHINE?HOPE THIS HELPS.ALI
Jun 30, 2012 | Sub-Zero Refrigerators
It just stopped making ice yesterday. A question.
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
Nov 29, 2008 | Refrigerators
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
