Question about Samsung CLP 300 Laser Printer
HI, I have a clp-300 and it is printing black only on the right side, but the left is completely washed out. it works fine when I use a color other than black
  • krille Feb 15, 2009
    I have exactly same problem If I print a side only yellow green or blue it works
    fine but black only at right side..
  • chumba68 Feb 16, 2009
    Hi, I have the same problem with the washed out black down one side and the printer is just out of warranty. I am interested in the document to clean the blades to see if this works.
    President:
  • 670 Answers
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I have a document to show you if you are handy.
Posted on Feb 14, 2009
  • Stephen Lam Feb 23, 2009
    If your printer looks like this:
    Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then then also needs to be cleaned.
    To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix... It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade.Otherwise when you print the side where the blade is not properly installed will have too much color.
    If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Samsung CLP-300: Black print is fading replaced black cartridge twice all the other colors print fine
Dear,
This is a problem with a black developer. in the imaging unit. Kindly approach authorised service center. they will change for you.
Sep 27, 2010 | Samsung CLP 300 Laser Printer
How to clean our samsung clp-300. Prints darker on right hand side than the left side.
control toner shake cartridge and try again
you can clean printer with dry air from compressor blow all the dust and toner thad are insite away control also small strip in the printer witch clean the rest of drum (about 1 cm with and 15 cm long)
Mar 02, 2010 | Samsung CLP series CLP 300 Up to 16 ppm...
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
MY CLP-300 PRINTER IS NOT PRINTING BLACK TXT WELL (OTHER COLOURS FINE) DESPITE HAVING A NEW BLACK TONER CARTRIDGE CAN ANYONE EXPLAIN WHY ?
Spend a little time searching the topic on google and even this post. It appears that this has been a well documented problem since at least early 2008. The problem appears to be the imaging unit. According to several posts, Samsung has replaced several of the units. I purchased my CLP-300 in November 2008 and it worked with no problems until about 8 months in. The black text would print very lightly on the left side of the page about 1/4 of the way into the page. There was also a streak that ran down the page vertically that disrupted the text. I could change the font to any color and it would print just fine. After replacing several toner cartridges, I just began to print in a dark color for many months. After discovering all the posts on the internet this week, I contacted Samsung today with my documentation and evidence. They basically blew me off stating that I was outside of the 1 year warranty period and there was nothing they could do. I was even hung up on by a Samsung employee named Michael. Tonight I plan to take a hammer to it to relieve a little frustration. I cannot understand why Samsung chooses to ignore this well documented problem. Good luck.
Jan 07, 2010 | Samsung CLP 300 Laser Printer
POOR PRINT QUALITY WHEN PRINTING IN BLACK ONLY
may be your new toner can be faulty.you can try this processor first you remove the toner & refix it after shaking.if your problem is not solved then check with new toner again.
Sep 02, 2009 | Samsung CLP 300 Laser Printer
Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
Jan 05, 2009 | Samsung CLP 300 Laser Printer
Black partial fading
It's either the opc drum is on it's way out or the charge roller/corona wire faulty or needs cleaning
May 18, 2008 | Samsung CLP 300 Laser Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
721 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
