Konica 7145 L detect
How is the L detect performed after changing developer in a konica 7145 copier?
  • 1003 Answers
SOURCE: Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Posted on Jan 13, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
jqsababa967
  • 145 Answers
SOURCE: Konica 7022 F-26-3/2 L detect 0004 Konica 7022
Details Subject:
Background, overtoning, and/or F26-x codes.
Description:
Solution:
PROBABLE CAUSES:
1. Overtoned developer.
Install fresh developer (PCUA 950237) and run the L-detect adjustment. To run the L-detect adjustment, perform the following:
a. Enter the 36 mode (power the copier ON while pressing the 3 and 6 keys).
b. Press [1. HV adjustment].
c. Press [Next] several times until the display reads [HV adj (L detection adj)].
d. Press [Start].
e. When the adjustment is complete, the machine will stop and a value is displayed in [RESULT].
f. If the developer was sampled properly during the L-detect adjustment, the value displayed in [RESULT] will be in the 60-75 range.
g. If the L-detect adjustment [RESULT] value is outside of the 60-75 range, than the TDS (toner density sensor) should be checked.
2. Failed TDS (toner density sensor).
To check the TDS, perform the following:
a. Remove the IP unit (if an IP unit is installed).
b. Remove the rear and left rear side cover.
c. Remove the board cover/D (p/n 26NA73280) for access to the PRDB.
d. Enter the 36 mode (turn the machine ON, while pressing the 3 and 6 keys).
e. Select [1. HV adjustment].
f. Press [NEXT] several times until the display reads [HV adj. (Toner auto supply)].
g. Locate TP14 (TDS AN) in the middle of the PRDB above CN 25.
h. Using a voltmeter (20V DC range), place the red meter lead on TP14 and the black meter lead to frame ground.
i. Press the START button on the control panel.
j. The analog voltage reading on the volt meter during sampling should be (with properly toned developer) between 1.2 and 2.0VDC. If the voltage reaches 2.0VDC, M4 (toner addition motor) will turn on and add toner. When the toner auto supply adjustment is finished the voltage should read approximately 1.8VDC.
k. If the voltage reading is not within this range, replace the developer (PCUA 950237), TDS (p/n 26NA88040) and run the l-detect adjustment while monitoring TP14 on the PRDB.
3. Failed write unit (the TCSB monitors dot pattern patches created on the drum and adjusts the laser output for Maximum Power Control).
If developer has been replaced, L-detect run, the TDS voltage checks, and the developer is still overtoning (M4 continuously adds toner), replace the write unit (p/n 26NA-6503).
4. Clogged machine filters.
Check all machine filters to verify they are not clogged. Clogged cooling fan filters prevent proper ventilation which can cause the adhesive on the write unit glass cleaner to melt due to high internal temperature, causing smears on the glass.
Note: Information provided by Matthew Kennedy, Perry Corporation.
SPECIAL NOTE: Solution contribution by Don St. Onge, Workgroup/SSD
Attachments:this is additional information on f-26-2
and i have given you info on f-26-3
you should revue all the information
hope that helps
Posted on Oct 14, 2008
jqsababa967
  • 145 Answers
SOURCE: Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
Posted on Nov 01, 2008
  • 158 Answers
SOURCE: I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Posted on Oct 15, 2009
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica 7145
fuser code hot part replace it
Apr 13, 2014 | Konica Minolta Konica 7145 Minolta Bizhub...
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
I need a solution for konica 7145 error code 26-3
F26-3: TDS (Toner density sensor output abnormality) Abnormal output from TDS (Toner density sensor) TDS output ripple voltage failed to reach 0.5V
Possible that developer needs to be replaced or Toner is not supplying into the developer Unit.
Service Manual available to your model at: http://fixmfp.com/index.php?route=product/product&path=60&product_id=52
Sep 06, 2013 | Office Equipment & Supplies
Konica 7145 i have an error message 0006 I have replaced drum in drum assy. it gave me an f26-3 error message performed L detection now it gives 0006?
Check Toner control sensor board, on drum unit behind drum, is clean, try L-detect then, try it a couple of times. If that fails you will then have to change developer, and perform L-detect.
Sep 13, 2010 | Office Equipment & Supplies
After changing developer on konica 7065 what is the st up procudre ?
You must perform ATDC sensor gain procedureF8 and AIDC sensor F5 perform.
Dec 28, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7145 Legacy Print Driver
konicaminoltaus.com has a complete list of the drivers for download on the site
Oct 09, 2009 | Konica Minolta Office Equipment & Supplies
Hi Just bought a Konica 1212 and P.27 keeps flashing. Please can you help. I have no instructions.
Only developer should be added during a new machine set-up so that toner does not cover the TDS sensor.
To eliminate the code:
a. Access the 47 mode, output code 40, and allow the main motor to run for approximately one minute. Any excess toner surrounding the TDS should mix with the developer.
b. Perform the L-detect adjustment again (47 mode, output code 51).
c. If the problem remains, repeat steps a and b.
d. If this does not correct the problem, replace the developer and perform the L-detect adjustment.
NEED TO REPLACE THE DEVELOPER AND DO THE ABOVE WITH OUT THE BOTTLE OF TONER IN THE MACHINE ,
Jun 27, 2009 | Konica Minolta DiALTA Di200 Copier
Eror code 82-2 konica minolta 7145
eror code f_26_1 konica minolta 7145
Feb 23, 2009 | Canon imageRUNNER 400S Copier
274 people viewed this question
k24674
