Question about Compaq Presario S4200NX (DF215AR#ABA) PC Desktop
HP Compaq 2810 SFF 250W Product number VD 282 PA # ABG. Upon pressing the start button a red light next to it shows and a alarm sounds. The fan runs fast continually. The boot up does not go any further.
acdr
  • 1913 Answers
SOURCE: "Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Posted on Nov 03, 2008
  • 233 Answers
SOURCE: Compaq Presaio S4200NX displays Compaq Splash Screen then a single continuous beep with but nothing else.
Maybe the hard drive is bad?
Posted on Dec 15, 2008
  • 90 Answers
SOURCE: power light comes on but nothing appears on monitor
Mostly your heatsink damaged your motherboaard. check caps lock LED and Number Lock LED are working after switching on. If not ur motherboard or processor get damaged and u had mentioned what happened. Ur heatsink shorts some circuit in  your motherboard
Posted on Apr 06, 2009
  • 18 Answers
SOURCE: dc7100 sff power supply
Part number :
349987-001 Switching power supply (340W) - 100-240VAC input, 45-66Hz
Posted on Aug 27, 2009
  • 1288 Answers
SOURCE: hp compaq desktop stopped running,
4 beeps indicates ram or video issues.
Try reseating the ram modules and checking the video card (or try a video card if you are currently using the onboard video)
Posted on Dec 30, 2010
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
May 05, 2017 | HP Computers & Internet
Solid Red light on hp compaq 6000, instead of green light. Does any one know why?
Yes, it means a bad Power Supply.
Try cleaning out the inside of the computer first. Use a can or two of compressed air for computers.
{Computer unplugged from power, Anti-Static Precautions observed}
How to open the computer case:
1) Work on a table
2) Computer unplugged from power
3) All cables removed from desktop unit
4) Observe Anti-Static Precautions
HP Support > HP Compaq Pro 6000 SFF > Manuals,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=101&prodTypeId=12454&prodSeriesId=4024462#3
Under the Service and information heading, left-click on the second file listed -
Maintenance and Service Guide: HP Compaq 6000 Pro Microtower Business PC
(11Sep2009 / PDF / 11.15MB )
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
{Took 22 seconds for the first page to come up, and no additional download time. Using medium speed DSL connection }
In the Bookmarks menu to the left, click on the + sign to the left of - Removal and Replacement Procedures Small Form Factor (SFF) Chassis, then on Access Panel
Or go to Page 123 using the page number box at the top, and the Down Arrow.
Clean the inside of the computer out. pay special attention to the Processor Fan, and the finned Heatsink under it.
Also use the plastic straw in the Power Supply's ventilation holes. Try to clean out the inside of the Power Supply the best you can.
(Hold onto the plastic straw with one hand, and the can of air with the other hand. If you do not, the plastic straw may come loose, and shoot inside the case of the Power Supply)
After cleaning close the computer case, reattach all cables, plug the computer back into power.
WAIT 1 minute, turn the computer on.
Still no?
Then it's time to replace the Power Supply.
http://www.sparepartswarehouse.com/HP-Compaq,6000-Pro,Computer,Power-Supply.aspx
The exact Product Number (P/N) is on a white Service Tag. On the back of the computer, or on the side. Usually next to the Windows product key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 03, 2011 | HP Compaq 6000 Pro Small Form Factor PC...
Dear sir, my desktop is hp compaq dc7600 sff. everytime when it starting to boot the following info is appears: "512- chassis fan is not found. press f1". after pressing f1 it's starting to...
The sytem checks for the Chasis fan during the bootup (startup) process. The fan is connected to the motherboard via cable. Turn off the system. Open it and make sure the the cable is connected properly. While the PC is open, press the power button and check if the fan turns on. If not the chasis fan may have gone faulty, which needs replacement. If you find it faulty, you may find and replace the fan by removing the old/ faulty fan by removing the 4 screws and installing the new one.
Hope it helps! Good Luck!
CreativeTECH
May 02, 2011 | HP Compaq d530 SFF PC Desktop
I have a d530 sff.when i press the power button a red light starts flashing
is your comp botting then there is no problem. if not check the smps
Jan 12, 2010 | HP Compaq Business d530 PC Desktop
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Mar 06, 2009 | HP Compaq d530 SFF PC Desktop
How to load sound card driver?
compaq and hp work together compaq is hp product.......
  if you want drivers(sound, video, graphics.. drivers) for you compaq presario c700
try visiting the website www.hp.com------> on the top u'll find Support and Drivers Link, click on it
------>Under "Select a task and enter a product name/number:" check the radio button showin
Download drivers and software (and firmware).
-------> now in the text box enter ur computer name "hp presario c700", i would strongly recommend u to enter the product number of laptop to get effeicient or correct result
product number: just upside your latop on its top or back you will find white color bar coded sticker with a hp logo you will find:
  S/N:
  P/N: which is product no, try to write it down and enter thisproduct no in the text box(effective than enter name of your computer) and press the arrow button beside it to start the searching
-------> no u will prompted to enter operating system, click the link under Select Operating system(click right OS)
------> u will find drivers(audio, video drivers......) in the page(try to explore the page) and download,
Note: make sure ur typing right product no
Congrats...
Surely i can send it your mail i have a low internet connection which will take a lot of to upload your driver to your mailing address, i aplologize.
Thankin you
M. Sridhar
Dec 14, 2008 | Compaq Presario 700 470024-192 Notebook
HP DC5000 SFF
Check the cables connection first.
Check if the power supply fan and cpu fan are working
If not you need to replace your power supply.
Let me know how it is going!
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 17, 2008 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
Will not boot up
The beeps are error codes there should be a system what it sounds like is 3 beeps then a pause and it starts again. go to www.support.hp.com and click on drivers and downloads then type in your model number and download the manuals there will be a chart stating what the beep code means if you have a warranty go to the liive chat and just have there technicians tell you what it means to save time then repair the error
Aug 20, 2008 | HP Compaq d530 SFF PC Desktop
HP Compaq D530 sff Will not power up
sounds like your power supply went out.
Nov 16, 2007 | HP Compaq d530 PC Desktop
Compaq Presario S4200NX (DF215AR#ABA) PC Desktop Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
