Question about Nintendo Wii Console
Connection problem one of our remotes was taken to my sisters house and the oter won't link up to the wii. The first screen appears where it says push the a button and when we do the wii remote doesn't sync... i tryed to push the 1,2 buttons but this also didn't work.. i unplugged the wii to no evale. i will get the other remote back tommorow but was hopeing to play today.
  • MTCHGORDIN Jan 18, 2009
    HOW DO YOU RESYNC THE REMOTES?
We got the other remote back today so no help is now needed..
Posted on Jan 18, 2009
Tip
How to connect you Wii to your TV, Out of the Box.
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
on Feb 15, 2010 | Video Game Consoles & Games
Hi! I am trying to connect my Wii to the internet in order to watch Netflix on my tv
Connecting to wireless network
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Now, select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection 1: None"
5.Click on "Wireless Connection" and then "Search for an Access Point."
6.Select "OK" and the Wii will display all the wireless networks it finds.
7.Select the wireless network that is yours.
8.Select "OK," "Save Settings," and then "Yes."
Download Netlix
1.Select the Wii Shop Channel on the Wii Menu.
2.A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account. 3.If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right. 4.If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
5.Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
6.Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.
After Netflix Instant Streaming for Wii has been added, the next thing you'll need to do is connect your Wii console with your Netflix account.
Connect your Wii console to your Netflix account
  1. On your Wii
    If you're not already on this screen on your television, select Netflix Instant Streaming for Wii from the Wii menu. (Don't have this option?) On this screen you will be presented with a code; remain on this screen during the activation process.
  2. On your home computer
    Using an online device other than your Wii console - such as a PC, Mac, or Web-enabled phone - go to http://www.netflix.com/wii. (You will need to log into your Netflix account if you're not already logged in.)
  3. Still on your home computer
    Enter the code displayed on your television into the box on the bottom Netflix Web page, then click "Activate Now." (The code is case sensitive.)
  4. Back to your Wii
    Netflix will now attempt to activate the connection to your Wii console. This may take several minutes. When the process is complete, the Wii will automatically display your queue. (The screen on your computer will not change. Wait for the screen displayed by the Wii on your TV to indicate the activation has finished before going to another Web page.)
  5. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu.
Jul 11, 2011 | Computers & Internet
How do i connect my nintendo wii to my wireless home network
From the wii home menu...
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
Feb 28, 2011 | Nintendo Wii Console
How to connect a tv to a wii
Feb 15, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
Cursor will not appear on screen
make sure your sensor bar is connected to the console! properly aligned in the centre of t.v! also reconect the controler by: open the sd flap on front, press red button, remove batt cover of remote and press the connect button! this will resync the remote! also check battery's!
Jan 04, 2009 | Nintendo Wii Console
Mario cart will not recognize my second remote.
Another possibility is that the original poster did not push the "+" button on the main remote when on the screen in Mario Kart to register additional remotes.
This happened to me. I was holding down the 1 and 2 buttons over and over on the second remote, watching the blue lights flash, but the remote wouldn't register. Eventually someone noticed the instructions on the screen to push the "+" button. When you push the "+" button, another screen appears to let you really register additional remotes.
In Wii Sports, there is no pushing of the "+" button to register new remotes... I had incorrectly assumed it worked the same way in Mario Kart and didn't bother reading the on-screen instructions.
Dec 24, 2008 | Nintendo Mario Kart (Wii) for Wii
Can't play with 2 players
Make sure you have paired both remotes to your Wii console.
Open the little door on the front of the Wii (under the disc slot), and open the battery cover of the Wii remote (but leave the batteries in).
Push the red button on the Wii (next to the SD card slot), then push the red button on the Wii remote (next to the batteries). You should see the Wii remote's lights blink.
Do the same for your other Wii remote.
Now on the bottom row of 4 lights on the Wii remote, one should have the first light lit, and the other should have the second light lit. You should also be able to see a cursor for each remote on the Wii Menu.
Apr 03, 2008 | Nintendo Wii Console
2nd Wii Remote will only not connect in Link's Crossbow Training
This is a ONE player game. It won't connect because the Wii isn't looking for any additional controllers. It's not a problem.
Jan 07, 2008 | Nintendo Wii Console
Remote malfunction
Do the LEDs light up when you press the buttons on the Wii Remote? Try simply turning off the console, and pressing the power button a couple times firmly on the Wii Remote. If it turns on the Wii, the connection should be established. If it doesn't turn on the Wii, some hardware is defective. Recommend calling Nintendo Support if this happens.
Aug 14, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
