Question about GE WBSE3120B Top Load Washer
GE washer - Excessive shaking in between phases
Hi all, the washer clunks at the end of each phase and does not automatically move on to perform its next task. however, ive found that i can manually set the knob to initiate the next phase. this works until it begins to shake/clunk again at the end of that phase. -ive checked the drain hoses, drain holes and pump and have found no clogging or residue of any kind. -ive also checked the tension on the belt and that is also fine. any further suggestions or info is much appreciated. thanks
  • 164 Answers
How old is the washer? depending on the age and the model the problem could be different things
Posted on Jun 23, 2007
SOURCE:
Hi!3-phase motor wires brn/blue/blk no open cct.P.c.b there are no components burnt out or blown.I removed interlock switch and will buy new one and try again.Belt ok.Pump solenoid valve ok .
Check for a motor start capacitor that is defective. This can happen without external symptoms. Highly unlikely Hotpoint washer has 3-phase motor. Most household loads are single-phase. In North American residences, three-phase power might feed a multiple-unit apartment block, but the household loads are connected only as single phase. In lower-density areas, only a single phase might be used for distribution. Some large European appliances may be powered by three-phase power, such as electric stoves and clothes dryers. Three wires could be for different speed ranges or one could be frame ground.
Apr 08, 2015 | Hotpoint Washing Machines
My 3 phase motor will not start. Just makes a clunk, but wil not rotate. Need help.
Clunk doesn't explain much. Check your voltage in. Unit may have been wired 440 volt and your supply is 220. Make sure you have all three phases coming in.
Dec 25, 2014 | Air Tools & Compressors
I have an old GE deep fat fryer,m/n CK40B, which has no wiring diagram, I am trying to use it for my shop, but can't find any diagrams anywhere on this fryer. It was wired for 3 phase, I am trying to...
If you feed single phase into the line terminals, you will get only 1/3 the heat wattage. To get all heating elements working on single ph, you'll have to separate the common ends of the elements, then connect all 3 in parallel. Keep in mind, doing so will raise your line amperage x3 also. That may put you over the contactor's max rating. Another thing, the contactor will activate on only one sequence of single phase. You may need to move the line to another 2 of the 3 connections.
Feb 02, 2018 | GE Kitchen Appliances - Others
During washing phase, the rotator is not moving - but you can hear the motor trying to move
your problem may be the drive belt. check that first. part# WH01X10353 you can find it at sears website or service center for about 15.00 plus tax and shipping.
good luck to you.
Feb 19, 2011 | GE Profile WPRE6100G Top Load Washer
How can one use a 3 phase wood lathe in a residential area where single phase power supplied. Have 50 amp breaker supply to shop. What is required to hook up 3 phase Centauro TC 1200 (Italian wood lathe)...
You need a phase converter. The link below is a a selection from Grizzly. You can also find them on e-bay. There are two types - static (no moving parts) and rotary (much more expensive). The rotary type give you full performance delivering true 3-phase power to your machine. But for a minor loss in power (maybe 20%) the static type does the job quite well - assuming you don't need all of the power that your 3-phase motor can deliver. Here's the link: http://www.grizzly.com/products/category.aspx?key=275030
good luck. Vote if you found this helpful. Al K
Sep 09, 2010 | Garden
New GE Profile dryer DPSE810EG7WT does not work. I wired exactly as old dryer. L1 L2 and neutral. The timer comes on but the machine does nothing! Thanks, Roger
if this is a gas dryer you would only need L1 OR L2.... NOT BOTH PHASES, this unit only needs the one leg of either A 120Volts or B 120Volts phase NOT BOTH PHASES 240 volts A.C. not 240 V.A.C. as in an electrically heated element will require to heat the system, NOW ...be careful now because one hot phase is connected where it shouldn't be!!!!
Apr 26, 2010 | GE DCVH515GF Gas Dryer
Motor or clutch ?
Clicking noises are most often associated with bra wires , sticking in between the drums , have a good look all around the inner tub with a torch if you spot a wire sticking through carefully pull it out with pliers but dont loose it , once it goes all the way through it is neccesery to completely dismantle tub assy to remove it.
Nov 03, 2009 | GE WBSE3120B Top Load Washer
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
GE WBSE3120B Top Load Washer Logo
53 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
