Question about Toro Garden
What drives toro 12-38 toro
Something seems to have become disconnected underneath that drives the mower backwards & forwards
    New Friend:
Question: Is theToro a hydrostatic drive? If it is check the oil level.
Posted on Dec 30, 2012
  • 255 Answers
SOURCE: no forward or backward movement
change your drivebelt
shack
Posted on Apr 19, 2009
  • 65 Answers
SOURCE: Toro Recycler 6.5HP recoil start cord pulls hard & snaps back in
This sounds like you have bent the shaft. This happens when you run over something hard. Hope this will help.
Posted on Jul 25, 2009
  • 77 Answers
SOURCE: My Toro Lawn Mower Model 20016 no longer moves
Your transmission is bad,need to have one ordered.
Posted on Aug 12, 2009
  • 67 Answers
SOURCE: Toro mower 20016 makes grinding noise and no
sounds like ether the the wheel gears are stripped or you have a bad trans.Pick mower up a little and take the bolt out of the wheel. The wheel will come right off check the gear on the inside of the wheel to see if it is stripped or worn out if not then it is the trans which are pretty cheap go to toro.com and look it up
Posted on Sep 02, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
I have a toro zero turn z4200 starts and runs fine but when I put arms in gear, it will not move forward or backward.
Make sure the drives are engaged. Under the seat and towards the rear are two thin metal levers with finger loops. These are used to disengage the drives in order to push the mower when the engine is off. Levers towards the back to engage.
Good luck
Mar 30, 2015 | Toro Garden
Why wont my toro move, as soon as i try to go forward or backward it shuts of?
Check that your operator present seat isn't disconnected.
Mar 15, 2015 | Toro Garden
Mower run but wont drive forward or backwards?
check the drive belt also is the release lever pulled the one that allows you to push it
Apr 15, 2012 | Toro Garden
My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Apr 03, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I bought a self propelled Toro mower and it is hard to pull backwards. I removed the plastic toe guard and that did not help. I also have a White "brand" self propelled and it is easy to pull backwards.
The self propel system uses a type of racheting pinion drive that sometimes gets greased up and wont release like it should.
You would need to remove the wheels and pinions and look at the shaft ends for a key, a ball and a spring. This is the "pawl" that locks the wheels going forward and rachets when the wheels go backwards.
Clean up the parts of all the aluminum colored grease and reoil with something lighter. 3 in 1 would do nicely. Reassemble.
Now the next time you start going backwards and it jams...just push the mower forwards slightly without engaging the drive and see if the unit doesnt free itself.
Good luck and be careful!
Jul 19, 2010 | Toro Garden
Drive doesn't disconnect when pulling the mower backwards...
Try letting go of the self-propelled lever a couple of feet prior to stopping, then try pulling back. Also, I had a Lawnboy that did this. There was a flap on the back of the mower that would curl up under the deck and actually push the transmission into gear when I pulled it backwards.
Oct 21, 2009 | Toro Lawn Mower With Toro Power Tools
Mowing deck is disconnected.
Place a block of wood under the disconnected side and have someone use a pry bar to lift it while you put in new pins.
Aug 15, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro lawn mower it is a little hard to go forward but does go. It doesnt go backwards at all. Can you help me! Joanne
Check the drive belt for flat spots. If it is ok then it is probably an internal transmission problem
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
175 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
