Question about Maytag PAV2300 Top Load Washer
Pav3200washer making grinding noise
When agitator moving it makes noise ,,is the drum suppose to me able to turn by hand ? and or the agitator to ,when machine is stopped.?,,,i took the belt off and niether turn by hand.1-15-09
  • Maytag Master
  • 8,220 Answers
The tub is supposed to be locked untill the brake is released. When the machine is in the wash mode the tub is locked or else the clothes would all get knotted up. When the motor reverses the brake is released and the tub can turn freely. Check the pump for bad bearing.
Posted on Jan 21, 2009
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
My Asko 10504 has started making what sounds like a metal on metal grinding sound when it spins. It's as if the whole drum assembly is moving more than it should and coming into contact with something,...
COULD BE THE TRANSMISSION SPRING OR TRANSMISSION BEARINGS. EVEN UR TUB BEARINGS IN THE TUB, A BAD MOTOR COUPLER HOWEVER U WOULD NOT GET ANY SPIN OR AGITATION IF THE COUPLER WAS BAD. BAD BREAKING SYSTEM WOULD NORMALLY MAKE NOISE BUT WHAT U WOULD GET THEN IS A COMBINED SPIN AND AGITATION DURING SPIN CYCLE,
Mar 23, 2015 | Asko Washing Machines
LG direct drive washer makes a grinding noise with power and moving it by hand. how much to repair?
sounds like the bearings have worn out. probably expensive, requires the machine to be dismantled almost completely.
Nov 12, 2013 | LG Washing Machines
What's the cause of my washer's agitation and noise problem?
Possibly a bad basket drive. Or something is wrapped around the shaft under the tub or something is in the pump.
Aug 30, 2012 | Washing Machines
Machine is making clanking and grinding noise during wash cycle drum does not appear to be turning. does not make this noise if ran without items in wash and drum turns with no items in the wash
You may have a problem with bearing. Place your hand inside the drum and see if you can move it up and down. If the drum can be moved up and down, you have a severe bearing problem that will require a technician to tear down the unit and replace the bearing and drum assembly. It's a very expensive job.
Good luck
Jun 16, 2011 | LG WM0642H Front Load
My washer is making a grinding, metalic noise when the agitator is supposed to be moving. Water enters and drains fine. The agitator moves very little and makes a great racket. Help!
Could be the belt or the bearing or both...
You need to remove the belt and test if agitator moves easy by hand, then it means bearing is OK
Apr 16, 2010 | Whirlpool Washing Machines
Agitator ''dogs'' not gripping, agitator spins freely; tub rocks
Likely a broken dog itself was making the noise. They should all be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Kenmore washer elite top load
sounds like you have a bad coupler.mach does not have a belt it uses a coupling system between the motor and trans.if you fill mach and it makes the same noise in agitation,replace the coupler
Sep 21, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
169 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
